55 cams on a 430
Old May 11, 2008 | 12:13 AM
nastyclk's Avatar
Supercharged CLK430 street/show car
55 cams on a 430
I hear rumors that you can install clk55 cams on a 430 is this true? What effects would this produce on a normal 430 and on my supercharged 430? How to they compare to other cams like schrick etc? Thanks
Old May 11, 2008 | 01:33 AM
MarcusF's Avatar
2002 CLK430
Most people who own cars that see boost (either supercharged or turbo’d) want cams that don’t see a lot of overlap. 55K cams may be a better choice.
Old May 11, 2008 | 02:51 PM
blackbenzz's Avatar
haters crazy
You think there is alot to gain on my 55 by going to VRP FI cams from the OEM NA cams?
Old May 11, 2008 | 03:35 PM
sick430's Avatar
CLK Cabrio
from what i hear yes. now that your car in sc the cams are causing part of the forced air out. the NA cams have a overlapping in the lobs which is great for NA cars as it helps suck in air. however on your car this overlapping is letting part of the air that is now forced into the chamber out. i have no idea about the vrp cams i hear they are crazy thou from the 55 guys better than the kleemann cams. hope this helps a little.
Old May 11, 2008 | 05:33 PM
nastyclk's Avatar
build boost
BB from my research and what people are saying our f/i m113 will probally see some tremendous gains from cams! If we are loosing pressure/boost from na cams because of overlap I can only imagine the power increase and boost added when aggressive cams are installed that reduce the overlap! I wish these damn things werent so expensive! One of my goals in life now are to get some cams for cheap!
Old May 12, 2008 | 07:50 AM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
i have a set of standard 55k cams for sale from my sl55. pm me if you want them.
Old May 12, 2008 | 07:02 PM
nastyclk's Avatar
How much?
How much?
