motor mount question
Old Jul 2, 2008 | 03:45 AM
funky102's Avatar
2000 CLK 320
I know there are 2 motor mounts. Are they both the same part? ie the front/left is the same as the back/right? Autohaus AZ don't seem to have it listed so I'm looking at mercedesshop and they have 4 different types. Which brand is OEM?
Thanks...
Old Jul 2, 2008 | 11:19 AM
OPALW208's Avatar
SL55, C63
Thanks...
the one's that are OEM will have part numbers starting with 208 ... ......
Old Jul 2, 2008 | 11:37 AM
MarcusF's Avatar
2002 CLK430
The 1999-2002 CLK430 and the 2001/2002 CLK55 use a single part number for both the left and right motor mounts. Same part, different sides of the block. Dealer part number 202-240-2917.
Now why doesn't the C43 show up as well . . . . . . .
Old Jul 3, 2008 | 03:44 AM
SaintMiles's Avatar
1999 clk 320
Originally Posted by SaintMiles
Yes. Get them both done at the same time.
Keep in mind, the left is the hardest one to do, so if they do that one in 1 hour, they should be able to do both in 1 1/4 hours. The left is a b itch(B ITCH) to get out of the cramped space down there, but the right side comes right out.
Also, if one mount is tore up, the other one is taking too much of a beating.
The 3rd(back, tranny) mount is probably ok, and it is very, very easy to do yourself with a floor jack and jack stands, and one size wrench.
I bought german made mounts for this car online(autoparts warehouse) for about 85 bucks a piece and it took me 2 hours to do it in my garage.
So expect to pay a mechanic shop about 110-125 for the mounts(each) and 1.5 hours at most. That would be reasonable for (maybe a)pro. If he's done it before, he could probably do it in less than half an hour.
375 ish.
I posted this to another motor mount question.
There are three mounts. Two front right and left, both are the same part, round in shape and are fluid filled. And one rear transmission mount, flat shape, rubber/metal sandwich.
I bought mine online at autopartswarehouse for much less than the dealer and they were German made, and matched up EXACTLY to the ones coming out of the car(original).
and apparently they want to charge for 3 hours of labor, so try to talk 'em down if you don't do it yourself
Old Jul 3, 2008 | 08:23 PM
clk430convert01's Avatar
2002 CLK55 AMG cabriolet
I was hoping this motor mount design has been improved over the past 10 years but if the numbers are matching then i guess they have not been improved. a 75k motor mount is unacceptable.............
Old Jul 7, 2008 | 06:53 PM
joeray's Avatar
2000 CLK 430 Conv.
I only have 45K on my car and have already replaced mine.
