Coolant Change
Also, anyone change their thermostat while changing the coolant?
My car seems to rum as hot as 229o F in extreme traffic. I wouldn't minde seeing if I can get a cooler thermostat for it. Anyone know if that exists?
The thermostat is simple and doing it with a coolant change makes sense. Two bolts and a big circular seal is all that's to it.
Is it something like this:
- Drain coolant from system
- Fill at radiator until coolant reaches top of radiator neck
- leave radiator cap off and start car
- watch as coolant level drops and add coolant as it drops
- allow car to reach operating temp and continue to fill as required
- when car reaches operating temp, close rad cap
Is that basically how it's done properly?
I’ve never had to burp my CLK. The reservoir is the highest spot in the cooling system so the air bubbles end up there.
Before draining, warm up the system with the heater at maximun (opens duo valve and therostat). This gets out more of the old collant.
