Is the Temperature Guage supposed to be slightly above middle?
Old Dec 23, 2002 | 12:34 AM
GForce83's Avatar
2002 CLK 320
My car only has 5000 miles on it, and I think it's overheating a bit. Can someone help me out? THanx.
Old Dec 23, 2002 | 03:51 AM
Mach430's Avatar
Sounds normal. Unless it's in (or close to) the red, you should be fine. What temperature would you estimate it's at?
Old Dec 23, 2002 | 05:13 AM
Pffelan's Avatar
CLK 430 Coupe + MGF + 1980 Camaro
MINE ALWAYS SITE ABOVE THE MIDDLE..
Old Dec 24, 2002 | 09:28 AM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Thumbs up
Mine works between 80 and 100, depending on conditions.
Old Dec 25, 2002 | 01:46 AM
nickv's Avatar
Used to be a CLK430
I seem to be at a constant 83 degrees once the car warms up.
Old Dec 31, 2002 | 12:04 AM
HofstraCLK430's Avatar
Mercedes CLK 430
my car sits above the middle also. No need to be worried.
Old Jan 2, 2003 | 01:33 AM
Newbie's Avatar
Yeah, a lot of Benzo engines are like that. Perfectly normal.
Old Jan 2, 2003 | 04:33 PM
derek m's Avatar
02 CLK55, 07 E92 335 ProCede
Post
If you are in montreal at the moment, the temp gauge will not even reach half.............too damn cold..........
Old Mar 22, 2006 | 10:56 PM
spshond's Avatar
2000 CLK-430 - Sold
I've been a bit worried over the last week because I've noticed that my temperature gauge has been sitting around the 80 - 90 degrees celcius mark. I'de say around 85 degrees without running the air condition. Per this thread, it sounds perfectly normal. Just want to make sure others out there still agree. Thanks 2000 CLK
