Gas tank
Old Oct 15, 2008 | 06:35 PM
zdfun's Avatar
2005 CLK 500 Coupe
Gas tank
Hi,
Question, I can't fill my tank full, it stops at 2/3 full. It happened after I had a smog check last week. Any idea? Thanks.
ZD
Old Oct 15, 2008 | 08:13 PM
OPALW208's Avatar
SL55, C63
Originally Posted by zdfun
Hi,
ZD
what do you mean "it stops at 2/3.."????
YOU control how much fuel goes into the tank.....not the pump.
Old Oct 15, 2008 | 08:33 PM
enyce284's Avatar
1998 CLK 320
maybe the floater is bad or the needle is broken
Old Oct 16, 2008 | 02:38 AM
KENNETH04S's Avatar
02' brabus modified ML500,05' Lambor Gallardo, 02' CLK
fuel level sensor went bad, may be?
Old Oct 16, 2008 | 02:31 PM
zdfun's Avatar
2005 CLK 500 Coupe
I heard if there is any problem in the gas tank, I have to change the whole gas tank, is that right?
Or is it something I can do by myself? Many thanks.
Old Oct 17, 2008 | 03:23 AM
babyboigsxr's Avatar
E55 AMG (SOLD), EvoSport CLK (SOLD), 2013 GsxR 750 (SOLD)
Some dude at school had a similar problem. he has a G35 and a C-Class. It happens to him every once in a while. During the hot days, and hard driving. the gas tank has lots of "hot air", so if you open that tiny flap and let it air out for a few seconds. it'll fill up.
try that.
it happened to me a few times before too. i was like... what the f*ck?
Old Oct 17, 2008 | 12:48 PM
zdfun's Avatar
2005 CLK 500 Coupe
Thanks, let me try.
Old Oct 22, 2008 | 06:54 PM
GiZzO's Avatar
CLK55 / E350 Coupe
Thanks, let me try.
Did it work? I have a friend with a Ford, pump always stops on her and its a major task to fill up. Ford quality FTW.
Old Oct 22, 2008 | 08:15 PM
2PHAST's Avatar
500E Signal Rot
The CLK actually has two gas tanks connected by a hose, so there could be numerous problems related to this. The most common is the tank senders, which seem to go bad and not report the correct amount of gas you have. Mine are off by at least 1/4 tank.
