Wiring loom, Cam and O2 sensor. This I couldn't believe, neither could my mechanic
I bought my CLK about 6 months ago so it was just coming up on the end of the warranty when the engine management light came on, I brought it to my mechanic and he plugged it in and it read "O2 sensor fault low voltage (Sensor 1 Bank 1)" seemed straight forward, or so we thought.
He rang the local main Merc dealership to check which sensor it was, they said that it's the one before the Cat but then he said something a bit worrying.
He said "When you disconnect it check and see if there is oil in the connection, if there is then the cam shaft sensor is gone which has allowed oil to run through the whole wiring loom feeding the sensors of the engine".
As you can imagine I went out to get it checked and seen with my own eyes the oil in the connection. As luck would have it I brought it back to where I bought it, at first they didn't believe me, they peeled back the protection on the wires and they were clean, but then another dealership in the same town got the same problem.
What actually happens is that when the sensor fails it doesn't register because it allows oil to seep through the actual copper of the wire so it cant send a fault signal. also because it's through the core of the wire it looks clean when stripped.
At the moment there's a new Cam shaft positioning sensor gone in and a new wiring loom and O2 sensor has been ordered. I think there's another part ordered and when I find out I'll tell yee.
Preventative action... I do believe that they've developed a connection that fits at the Cam shaft sensor that if the sensor fails, it stops it from going any further but alas it wasn't on mine. It seems it this model and years are proned to it... Mines a 01 and between the other dealerships I've asked I've found 5 others that were 2000 or 2001...
I'll keep you posted on my progress...
All I can say is Thank God for warranties...
Greg
Greg
It's an hour and a half drive away so its easier to just bring it out to my mechanic to check.
Waiting on the parts still, hopefully the end of this week or next week at the latest, will keep you posted.
