The Best Launch
Old Nov 8, 2008 | 05:30 PM
GiZzO's Avatar
CLK55 / E350 Coupe
The Best Launch
In your experiance whats done best for you?
1. Holding the brake taping the gas reving the rpms and release (ASR OFF + Tiptronic Shift)
2. Just slamming the pedal to kickdown switch (ASR ON + Auto Shift)
3. Controlled push of the accelerator within the limits of just loosing traction (ASR OFF + Tiptronic Shift)
For me its been #3
Old Nov 8, 2008 | 08:24 PM
MarcusF's Avatar
2002 CLK430
Before making the pass, do the adaptive throttle reset. With the car in drive, and a foot on the brake, raise the revs to 1000 RPM. When the light turns green, immediately move the pedal ¾ of the way down, and modulate it until full throttle is possible without spinning the rears. At full throttle, make sure the button under the pedal is pressed in. With almost 30% more torque, your 55 will requires a much better touch than a CLK430.
Old Nov 11, 2008 | 06:45 PM
GiZzO's Avatar
CLK55 / E350 Coupe
With ASR off and manually shifting?
Old Nov 12, 2008 | 12:34 AM
MarcusF's Avatar
2002 CLK430
I just leave it in drive.
Old Nov 12, 2008 | 02:21 PM
ApproachingZero's Avatar
Don't manually shift it.... It takes to long... It is not like a BMW.
Old Mar 4, 2009 | 06:57 PM
GiZzO's Avatar
CLK55 / E350 Coupe
So with ASR off?
Old Mar 5, 2009 | 01:28 AM
ahmed18881's Avatar
frankenstein 2001 CLK 430
the way i do it, ESP off, full brakes and half a throttle till it buildup to 1200-1300 rpm, shifter in 1st gear (s off course). let go and count to 3 to press full throttle with the kickdown, i used to long press it to D at 4000rpm or it will go in cut off for a fraction of a second if i shift passed that... now with the AMG Speedshift program it automatically shifts up
