can u turn off the the traction control completely w208 430?
Old Nov 15, 2008 | 11:02 AM
slickclk430's Avatar
99 CLK 430, 00 SS Camaro 500HP, 95 SC300 Lexus, 06 GSXR 1000
is there anyway to completely disable the traction control on a 99 clk 430?
Old Nov 15, 2008 | 12:58 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Dont you have the ESP switch on the center dash??
Old Nov 15, 2008 | 04:23 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
apparently that doesn't kill it 100%
Old Nov 15, 2008 | 05:58 PM
sfclk's Avatar
1999 CLK320
Id also like to know. Switching asp off doesn't completely turn it off.
Old Nov 15, 2008 | 06:54 PM
bobbyjo9's Avatar
Maybe the 430 is different, but with mine off I get the orange light on the dash and tires up in smoke if not careful. The only part of the system that remains "active" is the limited slip rear and no way,or desire, to turn that off.
Old Nov 15, 2008 | 09:16 PM
KENNETH04S's Avatar
02' brabus modified ML500,05' Lambor Gallardo, 02' CLK
My friend in MB dealer told me that even you turn off the ESP , you can only have 30% of fun, the rest still in the ecu. i don't know if that's true or not,
Old Nov 16, 2008 | 08:53 PM
thought so.. sucks.... when turn it off it only spins for a sec then it cuts off the fuel... no fun at all... wish there was a way it could be turned completely off.. if anyone could find out if this is possible and how to do it .. let me know
Old Nov 18, 2008 | 05:37 PM
i heard something about pulling a fuse at some point....do a search
Old Nov 25, 2008 | 06:15 PM
Boosted9603's Avatar
CLK55 AMG
Yeah, I've heard of some saying to pull a fuse or unplug the ABS. Never tried either.
Old Nov 26, 2008 | 12:22 AM
jeff9939's Avatar
W208-CLK430,W204-C240
pull out the ABS and EPS fuse, than ur dash should have 2 lights on.
U r on ur way ~~~~
Old Nov 26, 2008 | 12:38 PM
falls profet's Avatar
OH REALLY???!!!
I'm going to try this weekend.
So...if you pull both fuses, do you still have to use the traction control button or is the traction control just permanently off?
Does removing the ABS or EPS do any harm?
Old Nov 26, 2008 | 01:08 PM
Chappy's Avatar
AMG
ESP only reduces the electronic 'nanny', it does not turn it off. We do not have a limited slip differential - we have an 'open' diff.
The W208 does not have 'dyno mode' like many of the newer AMGs have. As da_guitarist and others have noted, you can remove a fuse to the ABS (and perhaps another), but this is not recommended.
All that being said, you can still have fun by switching ESP off.
Attached Thumbnails can u turn off the the traction control completely w208 430?-wet-track-1.jpg
Old Nov 26, 2008 | 01:15 PM
Old Nov 27, 2008 | 02:36 AM
sfclk's Avatar
1999 CLK320
does anyone know exactly what # fuse(s)?
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
