can you fit 20's on a clk 430
Originally posted by J Lucas
I believe one other person has done it with extensive modification but the question is why would you want to?
Re: 18's
Originally posted by Adonis
Which tire and size would you guyz/galz recommend for 18x8.5 & 18x9.5 wheels. I'm looking for a widebody look?
2MERKS (06-29-2021)
2000 CLK430
Re: Re: 18's
Originally posted by dronellis
For 18's u can use 225-40 and the rear 245-35.
225/40/18 front with 255/35/18 rear or
235/40/18 front with 265/35/18 rear
both of these setups are very good
QDParker (07-03-2023)
i was hoping to put 265 - 35 - 18's in the front and 275 - 35 - 18's in the rear . will this work?
without fender work
Does anyone have this setup?
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Ok how about 255 - 35 - 18's front and 265 - 35 - 18's rear
without fender work
without fender work
The same diameter will let the ESP, ABS, etc. work better.
275 on the back is not a problem, depending on your offset. 235 on the front is easy too. 245 can work with the proper offset, but it may stick out too much.
-s-
Originally posted by ibcre8nhos
If i wasn't going to lower my car but just put 20's on it would i ahve to get work done on the fenders? how much would that cost?
no u dont need to modify the fender at all..u should find a perfect offset...for 20's on CLK. I recomend that using 20x8 and 20x9 at rear or 20x9.5. remember use 245-35/20 SP 9000 they are the best tires..P Zero are too thick.
1 Post
02 CLK 430 Coupe
You should try out these calculators to help you with tire size and offsets.
http://www.err0neous.org/mbz/tirecalc.html
http://www.err0neous.org/mbz/offset.html
dronellis
clk's with 20's
you can absolutely fit 20" rims on a clk without any major adjustments. i am currently running 20x8.5 front & rears on my clk320 & tire size of 225/35/20 on both. However, i would recommend finding the proper offsets not just tossing any rim you like on em cuz the bolt patterns fit. i have Velocity V710 sport rims on mine currently. i just got 20x9 fronts & 20x9.5 rears for it though & i only have to roll the fenders. will run 255/30 in front & 275/25 or 285/25 in rear if i can find the tires, lol. good luck!
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
2003
http://en.wikipedia.org/wiki/2003
http://www.musicoutfitters.com/topsongs/2003.htm
Shuttle Comumbia and Crazy in Love, what a year...
R129 SL55 AMG & W208 CLK55 AMG
Sitting on 18" Monoblock Type 2 wheels.
Specs are as follows:
Front: 18x8 ET31 wrapped in 235/40/18
Rear: 18x9 ET35 wrapped in 265/35/18 ( 12mm H&R Spacers )
Tires are Hankook Ventus V12 Evo2
2002 MBZ E55, 2005 BMW 2005 645 Ci cabriolet, MBZ CLK 430 cabriolet
Hi Ahmed,
yours is an AMG CLK. NICE!!!!
On my standard 2002 CLK 430 can I fit these 18" monoblocks from my 2002 E55 AMG?
235/40/18 front with 265/35/18 rear Best tire size in your experience?
Thanks,
Quentin
Thanks,
Quentin
