Brembo BBK
Brembo BBK
I just had Brembo BBK for front and rear installed. Alignment is done too with front -2 rear -1.5. Car drives great and will play with alignment more.
couple of pictures to share with you guys. I still have a set of Brabus suspension, 275/30-19 PS2 tires, C32 AMG brake kit for sale. contact me teryps2@Hotmail.com
98 Black C43 , 08' ML320 CDI ,11 E63
color is brembo racing gold. Front 355mm rear 328mm. You have choice of slotted or drilled rotors when you order. I went with slotted because drill rotors cools down too fast and will produce carcks. Pluse the slotted groove digs into the pads better. You can also go with 380mm rotors up front , but I am trying to reduce weight on my footwork let those KW V2 work their magic . couple more pictures to share with you guys
Sure I will take some photo of inside. I remove the carbon fiber hood. The fitment was okay for me but it almost flip open one time on highway. I guess if you use hood pin then it would be okay.
