ECU tuning
I have a couple of questions. Did you get a long block (block and heads, but no intake or exhaust)? If so, did you simply bolt the 430 intake to the 55 block? The reason I ask is the 430 intake and the 55 intake are the same (at least in the US). However, many parts that bolt to the intake are different with ME 2.8. If nothing else, the 69mm throttle body from the ME 2.0 engine is smaller than the ME 2.8 throttle body (74 mm for both the 430 and the 55, but the 55 is physically different. Lay them side by side and you'll see). That restriction seems like it would rear it's head at higher speeds. Ditto the smaller injectors.
If you got a complete 55 engine, and you're running everything that came with the complete engine, did your ME 2.8 wiring harness simply plug into a ME 2.0 ECU? If you're running your original ME 2.0 wiring harness, are you running the ME 2.8 injectors? Did those just plug in?
LOL. Not quite. I still have the 430. I'll tell who REALLY knows. The C43 guys who have actually transplanted 55's. ProjectC55 is a good example. One day the CLK430 forum may mirror the W202 AMG forum and M113 500 or 55 transplants will be (almost) common.
( MarcusF), I've got a 2001 as you call it long block( block and heads only). I've used the fuel lines and injectors from the 55 and yes you're right the intakes are the same. I tried to use the 55s wiring loom but the pins are physically different for the 430 ECU. My 430 loom plugged straight in but couldn't work the secondary air pump so I've taken that off.
I've tried KLEEMANN in the UK, Brabus, a company over here called DMS and Mercedes themselves. No-one has answers unfortunately! I'll try MHP and the other forums aswell hopefully someone knows!! I didn't want to hand out £1400 + tax for a new ECU.
I'll keep you posted!
Kool keep us posted
I've put Shrick cams in. The car works fine with the 55 engine and 430 wiring. It accellerates very fast 0-62mph. Around 5.7 - 6 seconds, not forgetting it's a cab. Torque is incredible compared to my old engine. The car wheelspins on take-off!! I've still got the problem of running out of steam on kick-down 110+ mph, although on straight accelleration from low speed you don't notice it much because you're pinned to the seat!
The gearbox was a straight fit. It can handle way more torque and power than what the 430 has. Only problem is the final drive is higher in the 430 than the 55, not much, but it means slightly higher gearing. In 5th the car now does 95mph with only 3000 revs!!
It seems Mercedes doesn't want people messing with their cars. All ECU's come from the factory chassis coded. There are certain things locked, such as Ignition, and ABS, amongst others. Dealers just load a format on and that's it!
I'm still looking for cheaper options!
