CD Changer issues
Old Apr 11, 2009 | 07:14 AM
Pauljay's Avatar
'00 Mercedes 430/55 clk cabriolet
Angry CD Changer issues
Hi Guys.
I've done a search but no-one seems to have the same problem as me!
When I play my cd's it works fine then cuts out after around a song or two making a noise as if a fuse blew. The radio stays on and I can listen to other sources but no sound will come from the cd. It just says no cd.
If left for a while with the car switched off, probably 30mins, the cd will work again. What gives!!
The same thing will then happen if I play my cd's.
Can anyone help please!
Old Apr 11, 2009 | 01:54 PM
Chappy's Avatar
AMG
Does this happen every time you play a CD?
Old Apr 13, 2009 | 05:17 AM
Pauljay's Avatar
Hi, yes everytime.
I've cleaned the lens with a lens cleaning disc. Taken the magazine out to make sure nothing is jammed and checked that the wires to the changer are connected and not loose.
The radio and tape work fine.
Old Apr 13, 2009 | 07:55 AM
Chappy's Avatar
AMG
Mine does this too, but only on a rare occasion. Sounds like you have an issue with the fiber optic cable or have a bad changer.
Old Apr 13, 2009 | 05:22 PM
Pauljay's Avatar
Thanks for the heads up!
Are there any cheap fixes?
Is it better to buy a new system. I was looking at a Pioneer or Kenwood double din unit as a replacement.
Old Apr 14, 2009 | 01:24 AM
MarcusF's Avatar
2002 CLK430
A digital media receiver, a PAC SWI-JACK, an additional PAC SWI-CAN, a PAC OEM-Universal, the VW/Audi/Mercedes harness adapter, and a Motorola antenna adapter, will allow you to kiss CD's goodbye. The additional cables will allow you to use the steering wheel controls and plug into your existing wiring harness. The head unit will allow you to use a USB powered hard drive, a USB thumb drive, iPhone, or iPod, depending on which head unit you chose.
Old Apr 14, 2009 | 05:06 AM
Pauljay's Avatar
Thanks.
I'll look into that. It probably would be best to get a new head unit also I suppose.
Old Apr 14, 2009 | 07:36 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Originally Posted by Pauljay
Thanks.
...its 2009 Man !! whats a CD? use a USB stick on an aftermarket head unit. Much better sound too !
Old Apr 14, 2009 | 11:20 AM
MarcusF's Avatar
2002 CLK430
I followed your lead from another thread. Solid state flash drives are impervious to shock* and a $25 stick can hold one's entire music selection.
Caveat - if you can shock a flash drive hard enough to make it skip, you've probably wrecked the car.
Old Apr 14, 2009 | 01:40 PM
AMGMB's Avatar
1999 Mercedes Benz CLK430
haha i use a usb in myn and dam it holds like a thousand songs!! a lot better then changing cds ever 20 mins
