Speakers are dead--advice?
Hi, everyone. I went for a drive yesterday and discovered that the speakers on the left side of my car weren't working. All of them, front, back, tweeters--the entire left side was dead. It seems kinda wierd to me. Any suggestions re. how I can troubleshoot this problem? (I've worked on electronics, etc. before, but never in this car and I don't have any kind of manual. The owners manual is in Japanese, which I can't read.)
TIA!
whkento
edit--I forgot to mention that it's an '02 CLK 200K with the factory navigation system and CD changer (in the trunk).
TIA!
whkento
not sure but i think yours would also have an amp in the back. not sure where or what the wiring diagram is but you'll see it here on the forum somewhere. i did mine so long ago i forgot. i would first take the clips in and out to see if its a connection problem. if not take a self amplified speaker and tap into the input to see if the decks puting out anything to the amp. i doubt it would be your speakers since front and back went out at the same time. some factory amps are dual mono blocks so they have power wires for left and right channel check those on the amp as well before you replace it if that is the problem.
ow first things first before doing anything at all........ check the "balance" on the deck first! hehe.
2000 CLK430
TIA!
whkento
TIA!
whkento
Greg
I think you're right about the amp in the back. I'll get back there and start checking wire connections. I hadn't thought of the self-amplified speaker thing, but that's a good idea
I kinda hope it's the self-fixing thing that Greg described (though that may mean that it'll happen every now and then?) I wasn't aware that it was something happening to a lot of folks.
If I get it figured out I will, of course, let you know what it is/was.
Good news / Bad news
Well, guess what-- I took a short drive yesterday and sure enough, the speakers were working just fine. So, the good news is that everything's working well again. The bad news is that I don't know why it happened. I guess my car has the same little gremlin as a lot of other folks' cars.
Thanks for the replies / advice.
2000 CLK430
In any case I am glad that the (common Gremlin) worked itself out like it did for the rest of us.
Greg
Hmmm... yeah, now that you mention it, I recently had the battery replaced back there.
Well, I'm just glad I can listen to my music again.
1999 CLK 320 Coupe
on a related note: if just one single speaker is out (the one closest to the seat back in the door), is it possible that the problem could be a wire loose at the amp? i haven't examined the audio system at all, and the only other thing i thought it might be was a wire out on the speaker itself.
