KMAC CAMBER KIT AND KONI ADJUSTABLE SHOCKS
i was told at my local MB dealer theye won't do alignment cuz i have after market camber arms (rear) wtf
also for the front control arms (longer bolts) like $29.00 ea !! omfg
$10.00 ea herehttp://www.bimmerspecialist.com/part.../202-330-01-18 but i called them guy said is the same lent/size its not longer !
so whats the point then! any advise plzregards
There is a chance they may be in wrong. Also, you can use the factory eccentric bolts, in conjuction with the K-Mac, to get a little more adjustablity.
front , it did not change one degree at all.. front was -2.3 and right -2.2 b4 and after kmac
but the question is i dont see how i can get correct camber and use 19's the front will rub for sure. how do people even use 20's?
whats the deal?
whats the deal?
hmmm 20 i would not know..i think william has 20 and u might want to ask him.!!
i got my rear fixed but still having camber issues in the front..i bought the kmac kit and did not even help with .1 degree... everyone has been telling me to get the camber bolt and that should help..i havent bought them yet since going out of town but once i come back, gonna get the bolt and give it a try.
As for my comment, I was just repeating what he told me. Imagine a tangent line runing vertical from the front of the back tire to the back of the front tire - please excuse my weak illustration
O = Tire
|------| = distance he measured
O|---------|O
and told me that this measurement on each side of the car was off by a quarter inch or so. So essentially, if both rear wheels are aligned perfectly then the two front wheels were not aligned perfectly. One was slightly ahead of the other.
Any help would be great. Right now my steering wheel is slightly to the right.
price is hefty for just rear bushing! I'll get you guys some pictures anyway... one side with 19's and one side with spare!
i was sitting at -3.2 and now im at -1.7 which is very close to spec.
its not perfect or within the spec, but def its must better than b4.
u can buy diff pad to lower your car more and they go by #1 to 5.. 1 is the lowest. U need to get the #1 from e320 for your clk since clk goes to # 2 (the lowest).
u can buy the bolt from clk55 to gain couple more postive degrees but IT WILL NOT WORK WITH KMAC.
