Need access to convertible top motor relay
2002 CLK430 CABRIO
I know this relay is in the back of the trunk behind a metal wall. I am trying to remove this metal wall to gain access to the relay which I beleive is the cause of why my top will not open. I opened all the screws on the bottom as well as the 2 screws on top holding the roller cover that must be closed to hold the top in. I know there are more screws higher but I cannot access them due to the fact that the roller cover is still there. Any idea what I need to do to gain access to the screws that need to be opened to reach the relay. I hope it is the relay. The top issue by the way is. I open the latch the windows go down and when I hit the switch I get the slow blink. I check voltage on battery and that is fine I also checked the roll bar and it goes up and down when I hit the switch with no abnormal noises. In the last 2 days prior to the top not working at all it would not always open or close on the 1st try. Any help will be greatly appreciated.
I have the exact same problem only with my 2000 CLK320. I took one look at all the screws to remove from that metal cover and decided to ask for help as to whether or not there is an easier way to get to that relay.
Please let me know if anyone has the answer to this.
Thanks, dadala
Thanks, dadala
02 clk 55, 13 GL 450
Thanks, dadala
Thanks, dadala
Roll bar and top use the same relay for main power. Remove the felt strips and the luggage cover will come out. Dont tear at them and you will be able to re-stick upon re assembly. You can swap the fuel relay for the top relay to test.
No easier way.. just a bunch of bolts... not that bad
2002 Mercedes Benz CLK 430 Convertible
Convertible Top issues
I am having the same issue with the top on my 2002 CLK430 Convertible. We had sort of a warm day here in Florida last week, so I took the top down. When I went to put it back up, I heard a faint motor running but nothing happened. I was forced to take to the dealer and they told me it was the Top Pump(part number 2088000020) and it would be over $3000 including part and labor but could not garantee the issue would be corrected. I only have about 45,000 miles on this car and it had been garaged kept for the most part all its life. Not in a position to spend that kind of money so I have been taking things apart in hopes of finding the part and installing myself. Have hit a dozen road blocks along the way including locking myself out of the trunk. I hav everything apart and want to try the relay test that you suggested. Does everything need to be out back together in order for the test to work? Help. Stranded outside with top halfway open...
I'm still reeling from the dealer that told you it it was the pump (probably not), its $3000 (just stupid), and that isn't guaranteed to fix it! (isn't that why you brought it to a dealer?)
Sometimes I think these guys should just be brought up on fraud charges....
Did you ever remove the plate and ck the relay and fluid level?
Thanks Bobby. I went to a couple autozone/pepboy shops to pick up a new relay in hopes that is my only problem. They didn't have a relay so I purchased one from the Mercedes dealer for $70. Installed and put everything back together(with the excception of the metal plate in the trunk). Tried it again from both the up and down top positions(followed the manual top instructions from the owners manual that I finally got my hands on this afternoon.) When I hit the button you can hear the mechanism trying to initiate power and a motor like sounds, but it does not yield a lift or unlock the top storage compartment. This is very frustrating. The pump looks to be in excellent condition with no leaking. The hydraulic fluid reservoir is full. The dealer claims it is the convertible pump/motor per the diagnosis from the "computer" they hooked it up to. Just hard to believe considering this is a 2002 with 45,000 miles garage kept and treated very delicately. Breaks my heart to think about spending $2,300 on a new pump. I did read that someone else had a trunk lock replaced and somehow that fixed the top issue. Just hoping someone has other ideas...thanks
Does the rollbar operate? If it were a micro switch you would get the fast blinking. Your fuel pump uses the same relay. May just want to try swapping that relay in too since you know that is a good relay.
Great suggestion for rollbar that won't go up.
Thank you bobbyjo9! The suggestion to swap the relays to troubleshoot the inoperative pump was excellent. I found a Hella relay for $29 locally (MB quoted $79) and have the rollbar and top working again.
Guest
Posts: n/a
motor top relay
Hi, I have the same problem with my roof, had a Mercedes dealer close my roof after it stayed open, paid 500€ for this (they checked and told me the pump is broken). After reading a lot on internet it could just be the relay, so I would be very pleased to hear the part number of the Hella Relay. This is a cheap way to find out if it IS the relay. Replacing the pump will set me back 3500€ which is a crazy price to spend on a car which I bought new in 1999. Thank you for any help!
SPONSOR
DIY for access to the pump, relay, and cylinders, plus fluid flush
Folks,
BenzWorld member 'joetwa' has created some awesome DIY instructions for access to the pump (and thus the relay). These DIYs also include instructions on how to flush the hydraulic fluid (a must for any CLK owner at this point, if it hasn't been done before), and how to swap the two locking cylinders easily for upgrade. FYI, Top Hydraulics also rebuilds the pumps...
Here is the DIY - thanks again, 'joetwa': http://www.tophydraulicsinc.com/W208...eplacement.pdf
Attached below also a diagram with the location of cylinders and pump in your CLK...
Hope this helps,
Klaus
Hope this helps,
Klaus
I know when my relay went (it still clicked) we put it on a code reader and the error is something like "low power or voltage" and I wonder if this is what makes the dealers suspect the motor, the guide above is really good too, wish I know about it before I did mine a few months back,
