Front Rotors & Pads
Old Aug 10, 2009 | 08:47 PM
Preacherbarryg's Avatar
2001 CLK230
Front Rotors & Pads
Recently bought 2001 CLK230 with 60,000 and its ready for front brakes, looks like rotors need replacing also. I've not worked on Mercedes before, any advise is appreciated - special tools, etc.
Old Aug 11, 2009 | 01:22 AM
MarcusF's Avatar
2002 CLK430
See attached.
Remove the caps (31b) and then unscrew the bolts (31c). That’s what hold the caliper (31a) in place. Remove the caliper, the pads, and the carrier. After removing the screws that hold the rotor, you'll need a big hammer to break the rotor loose. If you've never done this before, I suggest the assistance of someone who has. If you have done this before, several good smacks on the hub will break it loose. During reassembly, Blue Locktite on caliper screws and the rotor screws will ensure they come off easily the next time.
Old Aug 18, 2009 | 08:47 PM
2001 CLK230
Great help! Thanks
Old Aug 22, 2009 | 08:00 PM
anisamy1's Avatar
Mercedes AMG
Did your problem get solved?
Old Aug 29, 2009 | 05:26 PM
2001 CLK230
Before I could try it, car went into limp mode. Mechanic says the shifter computer failed; its in shop now waiting parts.
Old Sep 1, 2009 | 01:07 AM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Good luck with that. Computer is like $1000. Have u spilled any liquids down where your cupholders are? Also, have your Indy look into the new connector for the Computers harness. These things can fail and cause tranny fluid to 'wick' up the harness and into the computer.
