Custom Camber Eccentric Bolts & Washers
Old Aug 18, 2009 | 07:18 PM
Ghostrider's Avatar
01 CLK 430
Since I didn't want Williams to feel bad, I figured I would post soe pics as well...
These are the new bolts and washers that I had my machinst make to work on my front camber. I made my own arms for the rear so that is pretty much dialed in. I have also attached a print out of my alignment, the funny thing is it more to help the caster and toe than the camber itself.
Attached Thumbnails Custom Camber Eccentric Bolts & Washers-dscn3525.jpg   Custom Camber Eccentric Bolts & Washers-dscn3526.jpg   Custom Camber Eccentric Bolts & Washers-dscn3527.jpg   Custom Camber Eccentric Bolts & Washers-dscn3528.jpg
Old Aug 18, 2009 | 07:27 PM
Ghostrider's Avatar
01 CLK 430
Here's the alignment.
File Type: pdf
Old Aug 18, 2009 | 07:54 PM
Ghostrider's Avatar
01 CLK 430
Here are the rears.
Attached Thumbnails Custom Camber Eccentric Bolts & Washers-p1-performance-engineering-camber-kit.jpg   Custom Camber Eccentric Bolts & Washers-kit-installed-d1.jpg   Custom Camber Eccentric Bolts & Washers-kit-installed-p1.jpg
Old Aug 19, 2009 | 12:59 AM
Williams707's Avatar
2000 CLK 320
Ok, you are holding out on me
Old Aug 19, 2009 | 10:30 AM
Ghostrider's Avatar
01 CLK 430
I thought I had posted about the rears a long time ago, but I couldn't find it. I've had them on for years now!! They are made from aircraft grade aluminum.
Old Aug 19, 2009 | 10:51 PM
blackbenzz's Avatar
haters crazy
Where did you get your alignment specs? I got mine done at mb and they are wayyy different. I have a feeling the mb specs were off because I was rubbing like crazy when I got it back and I rolled the fenders and everything and still rub I never rubbed before. It has crazy specs like -2 rear camber, -2.5 front camber, 6 caster, etc. Those numbers dont make sense to me bu tthats what the mb sheet calls for target range
Old Aug 19, 2009 | 11:48 PM
babyboigsxr's Avatar
E55 AMG (SOLD), EvoSport CLK (SOLD), 2013 GsxR 750 (SOLD)
Pretty impressive Ghost. You know that i'll be messaging you soon enough.
Old Aug 20, 2009 | 01:32 PM
Ghostrider's Avatar
01 CLK 430
I got my specs from the dealer out here, and the big difference is that your car is a monster!! The alingment rack may just be afraid of it...
The more I think about it, what wheels did you have on during the alignment? I can tell you that the dealer will do alignments with the larger wheels on the vehicle, but you get better results using the stock 17's.
Old Aug 20, 2009 | 01:34 PM
Ghostrider's Avatar
01 CLK 430
Thanks bro!!! I'm looking forward to it!!
Old Aug 22, 2009 | 07:34 PM
anisamy1's Avatar
Mercedes AMG
Can you post some pics of these things and where I can find it?
Old Aug 24, 2009 | 03:42 PM
Ghostrider's Avatar
01 CLK 430
Pics are in the third post.
Old Aug 25, 2009 | 01:12 AM
SoCalw11w123's Avatar
Where can one get some rear camber arms like yours?
i want a pair....(sick of seeing my local tire dealer )
Old Aug 25, 2009 | 12:02 PM
Ghostrider's Avatar
01 CLK 430
Shoot me a PM.
Old Aug 25, 2009 | 11:10 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
They also have these already on ebay, They are under $220 on ebay for fully adjustable camber arms. I think they are under "mercedes camber arms" hope that helps.
Old Aug 26, 2009 | 06:49 PM
Ghostrider's Avatar
01 CLK 430
But that's more than they should cost...
Old Aug 26, 2009 | 10:57 PM
AMG
not really, those benzboy ones were $299+ so that is a discount for fully adjustable camber arms.
Old Aug 27, 2009 | 01:03 AM
sfclk's Avatar
1999 CLK320
How long did it take to install the sway bar? Did you install a front sway bar also. Please email me a quote on the rear camber arms.
gotkix@gmail.com
Old Aug 27, 2009 | 06:37 PM
Ghostrider's Avatar
01 CLK 430
If something costs $299 and another cost $220, that doesn't constitute a discount. That just make one expensive and the other, more expensive.
Old Aug 27, 2009 | 06:39 PM
Ghostrider's Avatar
01 CLK 430
gotkix@gmail.com
It was like 2.5 hours for the front and the rear sway bar and I do have both installed.
I can do that!
Old Aug 28, 2009 | 01:10 AM
2000 CLK 320
Hello hommie, don't waist your time responding to this guy. If you read some of his posts you will fully understand I'm not impressed
Old Aug 29, 2009 | 12:31 AM
Ghostrider's Avatar
01 CLK 430
Hello hommie, don't waist your time responding to this guy. If you read some of his posts you will full understand I'm not impressed
I hear ya bro!!!
