19 inch rims on 430
Old Jul 30, 2009 | 09:06 AM
Thunderdome66's Avatar
99 CLK 430, 84 v8 rx7, 97 gtp grand prix
19 inch rims on 430
anyone running 19 x 8 rims 35 offset 235 35 19 tires on a clk 430 stock suspension, just wondering about clearance issues as I ordered a set and they said the rims would fit but I might need to roll the front fenders? thought someone might know for sure
Old Jul 30, 2009 | 03:52 PM
OPALW208's Avatar
SL55, C63
do a search. this subject has been brought up hundreds of times.
Old Jul 30, 2009 | 06:16 PM
SoCalw11w123's Avatar
19" rims on stock suspension will look like a 4x4!
Old Jul 30, 2009 | 06:17 PM
tc1728's Avatar
it will fit
Old Jul 30, 2009 | 11:07 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
it will fit..i drive clk 320 and i have 19 rims and they are 235 19 35
Old Jul 31, 2009 | 07:47 AM
thanks for the replys guys btw I did look for about a half hour for this set up but couldn,t find it so I figured I'd post, is it hard to lower these cars? I've read about changing the pads to lower them, is this just the pieces of rubber that the springs sit on? also where would you buy parts and how low do you think I could go thanks again
Old Jul 31, 2009 | 10:54 AM
yup, changing or 'deleting' the spring pads will lower you car, just a little bit.
Its going to require you to remove the springs on all 4 corners, so might as well install 'new lowerings springs'.
CLick below to see my ride on 19's with 235/35/19 and eibach springs on #2 and #1 spring pads.
https://mbworld.org/forums/clk-class...y-rollers.html
Old Jul 31, 2009 | 11:42 AM
wow that looks pretty nice and even are the #1 pads on the front or the back if I might ask also where would you pick up the pads I might have to get this done soon thanks
Old Aug 1, 2009 | 06:09 PM
and this is mine: https://mbworld.org/forums/clk-class...clk-320-a.html
u get them from the dealer and they are about $9.95 each..basically $40 all four.
Old Aug 14, 2009 | 07:19 PM
Sick_Made's Avatar
clk 430
MY BROTHER HAD 19" ON HIS AND IT WAS FINE.... IM ALSO THINKING ABOUT PUTTING 19'S ON MINE IF I KEEP IT....
THERES PEOPLE ON HERE THAT PUT 20'S ON AND LOWER THERE CLK SO IM SURE ITS FINE
Old Aug 22, 2009 | 08:24 PM
anisamy1's Avatar
Mercedes AMG
It will fit easily, without any problem?
Old Aug 28, 2009 | 06:24 PM
Sick_Made's Avatar
clk 430
it shouldnt be a problem, i doubt it will be, it wasnt for the people i know that did it, are you from the bay area by any chance?
Old Aug 29, 2009 | 03:34 AM
Mika83's Avatar
Mercedes-Benz CLK320 MY2000
Still better than 18"s on any suspension though. IMHO.
19" is the way to go, you can lower your car later on if you'd like. Personally i'm running 19's on stock suspension and it looks good i think..no problems whatsoever with clearance, even if i load the car to the max.
