After market head unit RCA line out to speaker wire bose amp
I already have a 4-channel quality Eclipse amp so instead of using the Bose amp with OEM-2, I was thinking I would run the front door 6.5/tweet components from 2 channels, then run the rear door and deck from the other 2 channels. I don't see why not. This would just kick the rear channels of the amp into 2-ohm load, which should be fine wit a quality amp. Does anyone see a problem with that? Maybe even try to fit 8" components in the back for good mid-range, then putting my BassLink sub in the trunk.
I should be able to splice my new amp outputs into the the factory BOSE amp output wires for the door speakers right in the trunk per the diagram that is posted (big help, thanks.)
Any opinions?
Any opinions?
I looked up the specs of my Eclipse amp and is states 40w/ch @ 4ohm, or 60w/ch @ 2ohm (13.8v power). Model 3640.
I think it's hooked up now with the OEM-2 and Eclipse Nav unit installed. I want to replace with Pioneer Nav unit and replace the speakers. I suppose I will start with replacing those and adding the sub and see how I like it with the Bose amp. It won't be too much trouble to add my amp in the trunk since the battery and speaker leads are all right there. I will just need to run the extra RCAs when I install the sub.
