Cure For Body Roll On Clk
.........I just picked up my car after adding Renntech front and rear sway bars to the Kleemann speed sensitive suspension. I wish there was a way to let everyone drive it. THERE IS ABSOLUTELY NO BODY ROLL. It actually feels quite odd driving the car now because mentally I have come to expect some body roll as a natural aspect of driving. With ZERO body roll, it feels very unusual when conering. This is really amazing. I don't think it is for everyone because I can see how someone that does not do spirited driving might feel like they are still going straight while they are conering. Very odd to explain. But if you want absolutely no body roll whatsoever, get a Kleemann speed sensitive suspension and combine it with Renntech front and rear sway bars.
Ted
Ted
What is the diameter of the Renntech bars vs the stock CLK55/Eibach bars?
I agree, with the CLK55/eibach sway bars, I have absolutely no body roll. Now we just need to stiffen up the chasis.
Lol, nah not yet.
I can bring in CLK55 sway bars from Germany, but since this is not something commonly ordered, we will not stock it. The bars will be approximately $500-$550 with bushings. If anyone is interested, please let me know, as we have a container of parts about to depart.
Thanks,
Ben
Thanks,
Ben
..............I don't know the official numbers. But they are definitely thicker than the CLK55 bars. Mbautowerks did the install and they own a CLK55K with stock bars. They were amazed at the thickness of the Renntech bars.
Ted
Ted
so ted do you konw wether or not the renntech ones that u got are the same as the ones that sleestack got.... the mkb ones.. just with a different tag on sayin renntech and $1000?
I don't see why they would need to be thicker, the CLK55 bars are awesome!
............There were no inscriptions on the bars, so I couldn't tell. If Sleestack's MKB bars have inscriptions on them, then these are different.
.............I am not trying to knock the CLK55 bars. Actually, I got the Renntech bars because I could not find the Eibach/CLK55 bars. Having said that, the Renntech bars are thicker and offer significantly less body roll. The shop that installed my bars have a CLK55Kwith the CLK55 bars as well as Kleemann suspension. After installing mine and test driving it, the difference was obvious.
Ted
Ted
.............I just went under my car and measured the front sway bars. They are 11.5cm or 4.5 inches in diameter. I do not know the diameter of the MKB or the CLK55 bars. If anyone knows, please post the info. I do not think that the Renntech amd CLK55 bars are the same because visually, they appeared different to the mechanic that did the instal, performed differetly and i was able to get them in one week whereras the Eibach/CLK55 bars are not available. I do not know if the Renntech and MKB bars are the same,. Sleestack may wish to post the diameter of his bars since he has the MKB ones.
Ted
Ted
2011 GL450
Ted
Ted
Are we talking spring here?
I'm a little confused?
Tim
Ted could have meant 115 mm circumference...which would make the Renntech swaybars between 1/4 inch and 3/8 inch thicker then the CLK55......I guess that is possible from some of the other Renntech sways I have seen in the past.
Oberklasse quoted me $1680.00 for the CLK swaybars last year....way too much!!!
............sorry for the confusion. I meant 11.5cm circumference or 4.5 inches circumference.
Ted
Ted
.............using the formular: Circumference= 2multiplied by pie, multiplied by radius, and using the constant 3.14 as pie and 115mm as the circumference............the radius of the Renntech front sway bar is 115 devided by 2X3.14 which is 18.3mm. This makes the diameter 36.6mm. There you have it.
Ted
Ted
..............Ben, I don't have a problem with the CLk55?Eibach sway bars. They are simply not available. I know they can be special ordered from Germany, but that takes a while. The Renntech bars are available. I got mine within a week. They are more expensive but since they are thicker, the extra cost is justifiable.
Ted
Ted
I'm not putting down your bars either, as I have no experience with them to base it on. But from my experience, the CLK55 bars are perfect. Thicker does not necessarily mean better. Too thick can result in oversteer, more understeer, or loss of control easily.
I am getting pricing from Germany as we speak for the CLK55 bars. If anyone is interested, let me know, as like Ted Baldwin said, they aren't in the country.
.................These are not "my" bars. I don't work for Rentech. Infact I generally do not like Renntech because they a bit more expensive than is warranted. However, since the Clk55/Eibach bars are not available anymore from Eibach, I am trying to provide people with accurate info. There is no oversteer or understeer with the Renntech bars whatsoever. An experienced mechanic who has the CLK 55 bars in their car seems to think the Renntech ones offer less body roll. It may be the case that he Renntech bars are the same as the MKB bars in Sleestack's car. But no one knows so far. In summary the Renntech bars are great. According to you, the CLK55 bars are great also. Since only one of the two is available, anyone looking for sway bars has only one practical option. I just did not want to leave people with the wrong impression that there is any problem with the Renntech bars other than coost.
Ted
Ted
