Voltage Regulator?
Old Oct 28, 2009 | 11:29 PM
rolaes62's Avatar
2001 C320, 1997 E320, 1993 300e & 2005 F150 Supercrew
Voltage Regulator?
Hello all,
I think my voltage regulator is going out, Is it possible to just change out the regulator or do I need to buy a new alternator? I've done some baseline troubleshooting and everything is pointing towards the voltage regulator. (I won't go into details).
Any inputs would be appreciated.
Thanks in advance,
Rusty
Old Oct 29, 2009 | 03:59 PM
MarcusF's Avatar
2002 CLK430
Yes. The regulator is a normal wear part and can be replaced. This may be of assistance.
Old Oct 29, 2009 | 05:56 PM
rolaes62's Avatar
Cool,
Thanks Marcus. I thought it was possible, But I wanted to make sure and ask you experts. You guys haven't steered me wrong yet.
Regards,
Rusty
Wow thanks for the article!
Old Oct 29, 2009 | 07:06 PM
gregory13lil's Avatar
2000 CLK430
MARCUS ALWAYS HAS THE ANSWERS!!!
Greg
Old Oct 30, 2009 | 12:34 AM
MarcusF's Avatar
2002 CLK430
I have some answers, but WILLIAMS707 (what's the 707 stand for?) has THE answers!
https://mbworld.org/forums/clk-class...rk-lights.html
Old Oct 30, 2009 | 12:37 AM
VIPclk320's Avatar
CLK W208
I think i may have the same problem. when i'm behind a red light and i press on my window switches even if the window is already down my car shakes a bit, is this what the problem is? thanks marcus in advanced.
Old Oct 30, 2009 | 03:03 PM
928Benz's Avatar
1999 E300 TDI, 2000 CLK430, 2000 E320, 2003 S55, 2005 SL500, 2011 ML350
I too may be experiencing simlar issue. When stopped at red light, my interior dash lights seem to dim and car seems to want to stall out. I usually prevent this by holding the brake and giving a little bit of gas to keep the rpms up. If i try to roll windows up or down, the dash lights also dim. Do you think voltage regulator is suspect for these symptoms? Thanks in advance for your input.
Old Oct 30, 2009 | 06:24 PM
onlinealias's Avatar
CLK430
In your case, it is probably just the battery...I would start there, then move on to the voltage regulator.
Old Oct 31, 2009 | 01:38 AM
MarcusF's Avatar
2002 CLK430
VIP and 928, using option number 24 of the AC diagnostics will tell you how much voltage you've got at various times. That's one way of determining if the voltage regulator is worn out. If it drops to 12.anything (while running), that's low for my car - and the ECU will do wacky things with low voltage.
A rough idle may be motor mounts. Those are normal wear items.
