driver seat problem
Old Feb 15, 2010 | 01:25 AM
VIPclk320's Avatar
CLK W208
driver seat problem
hey everyone, i have a problem and i'm hoping someone can help me out. so here it goes. when i'm sitting on the seat i can't do any adjustments but as soon as i get up i can use all the adjustments, is theer a weight sensor or something. also everytime i hit a bump or something or i put pressure on the back rest piece i hear the noise that the seat makes after you droped the side handle and it has lock itself in place, i know the noise is from the motor that is back there that locks the seat in after you droped the side handle after letting someone in the back seat. any help would be fantastic.
Old Feb 19, 2010 | 02:56 PM
rjlawlor646's Avatar
2001 CLK 320
it almost sounds like when weight is put on the seat, its causing some type of a break in the electrical that wont let you move the seat. I could be completely wrong but idk what else would explain this. Try removing the seat and taking a look under. Its really easy to take out, only 4 bolts holding it down. Just check to see if maybe there are wires not completely plugged in or something.
Old Feb 19, 2010 | 06:59 PM
VIPclk320's Avatar
CLK W208
Ive done that and changed the seat computer and no go.
Old Feb 20, 2010 | 02:11 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Ok... try not to laugh but are you a big guy?? No disrespect but try having your wife take a seat and see if it works for her? that may give you a direction to look
Old Feb 21, 2010 | 12:41 AM
VIPclk320's Avatar
CLK W208
lol, i'm not huge but not small either 210lbs, and that was the first thing that came to mind so i did ask my wife who is only about 110lbs try it and same issue.
Old Feb 23, 2010 | 02:01 PM
bobbyjo9's Avatar
well it was worth a shot... if it was just 1 id say weak motor but all three!! Thats just plain weird. Would be a PIA but you could try swapping controllers to see if the problem moves driver to pass??
Old Feb 23, 2010 | 11:53 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
LOL your keer must be too heavy baba LOL
Old Feb 24, 2010 | 03:16 AM
VIPclk320's Avatar
CLK W208
lol. Yessir, I think it is my keer. damet garm aziz.
