Please help me decide on projector headlights
Old 03-10-2010 | 11:03 PM
dlbehrns's Avatar
99CLK320,
silv, the fender lined up exactly where it was in the first place. need I repeat myself? you have a one piece bumper. we dont'. heard of touch up paint? whatever.
Old 03-11-2010 | 06:10 PM
Silv430ClkR's Avatar
2002 Clk430
ok it lined up big deal, you DONT hav to unbolt them in the first place, let me rephrase that, youe SHOULDNT unbolt them in the first place, your trying to save some time doing something the WRONG way!!!!! 1 piece, 2 piece whatever it is just remove the bumper, your bumper isnt much differnt to remove, they have the same mounting points. TOUCH UP!!!!!!!!! what is this a kia were talkin bout, crawl back into your little hole, H*MO!!! idk of any GUYS that say "Whatever" at the end of a hateful comment!!!!!what, you gunna tell me to talk to the hand next. ROFLMAO!!!!!!!!!!!!!!!!!!!!!! (if you are a girl, plz excuse my language and i take back everything i said, your right, im wrong)lol
Old 03-11-2010 | 10:17 PM
dlbehrns's Avatar
99CLK320,
Old 03-11-2010 | 10:26 PM
milk42's Avatar
1999 CLK 320
So You guys think that I should use the Angel Lights and the normal lights for the headlights? Or should I just use only normal light?
Old 03-12-2010 | 01:20 PM
nelson09's Avatar
1999 E320
Normal
Old 03-15-2010 | 04:41 AM
milk42's Avatar
1999 CLK 320
I am getting the halo headlight soon.I just wondering what kind of light bulbs do we use for the high/low beams and parking light? I wanted to change to a brighter color halogen one, but not sure if the stock light (H7) will work for these? Also, you guys know any good light bulbs for headlights? I kind of want to get the bright one.
Old 03-15-2010 | 12:14 PM
  #32
nelson09's Avatar
1999 E320
I ran "super white" or blue glass H7 bulbs in my projectors for a while and as soon as I got my HID kit in it made a world of difference. The kit I got was from a company called APEXcone. Water proof 1 year warranty and they don't throw error codes. I got the 8000k kit. They are bright, crisp white with a tiny touch of light purple. A lot of people run 6000k because the color out put is lower but the light is brighter. For my inners I finally found an LED bulb that matches and doesn't throw error codes. The HIDs I got from the RPMstore in Costa Mesa for like $60 and the LEDs I ordered from JDMtoy dot com for like $26 or so. Congratulations and good luck.
Old 08-15-2010 | 07:58 PM
  #33
GiZzO's Avatar
CLK55 / E350 Coupe
Originally Posted by Silv430ClkR
Believe me its simple, heres the instructions on removing the bumper from the how to section:
Remove Front Bumper:
You'll need an 8 and 10 mm ratchet, a 13 mm open ended and a phillips head screw driver.
1. You need to detach the fog light splash shields from the car (you can leave them attached to the bumper) using the screwdriver.
2. Using the 8mm, disconnect the 4 bolts around the headlights.
3. With the 10mm ratchet, remove the bolts on either side of the bumper where it meets the fender (near the wheel).
4. To access the next two fasteners, you'll need to remove the side marker and part of the impact strip (or remove it from underneath the car). They're elongated bolts with a 10mm head on either side of the bumper. Loosen them until they drop down but don't remove them from the bumper.
5. Finally, remove the front fan shroud and you'll be able to access the two 13mm nuts. Remove them.
6. CAREFULLY remove the bumper (it is advised to have 2 people do it so that you don't scratch the fender with the sides).
7. If you didn't disconnect the wiring and temperature sensor from below before removing all the hardware, then disconnect everything before you pull the bumper very far off the car.
Make sure to organize the bolts so that you know where they go back. I drew a picture of the front of the car on a pad and placed the bolts on there so I remembered.
It should take about 40 minutes the first time. The bumper is quite light, so it should just slide out. If it doesn't, then you forgot some bolts. Compliments of Josh K and str8ridin
Can the fan shroud removal be skipped? that plastic peice pisses me off. Can be access for under the car the 13mm nuts described above?
^ oops my bad i was looking at the rear shroud
Old 08-17-2010 | 11:34 AM
  #34
luvgenuwine's Avatar
1998 clk 320
Projector Lights
Check out mine...
ToyzRUs
Quick Reply: Please help me decide on projector headlights
