Illuminated door sills?
Old Apr 21, 2003 | 12:17 AM
lionj's Avatar
Hi guys,
Does anyone have step-by-step instructions for installing the illuminated door sills? I think they look great and would love to make this an addition to my clk. thanx in advance.
99 clk320
Old Apr 21, 2003 | 08:58 AM
Timster's Avatar
2011 GL450
(The following is a step by step installation with out pictures of how to install illuminated door sills).
If you want the pictures included, send me your e-mail address.
(It's a very large file)
Installation of Illuminated Door sills on a CLK55 AMG
This is a Do It Yourself (“DIY”) installation of how to install aftermarket Illuminated door sills.
I installed the Illuminated Door Sills on my 2002 CLK55 AMG. This should work for just about any Mercedes that Illuminated doorsills are made for. If you are trying to adapt this to a sedan or SUV just repeat the process for each additional door.
Tools needed:
DC Volt meter Electrical Tape
Wire cutters Heat shrink tubing (optional)
Wire stripers Soldering iron and Solder (optional)
The first picture is what comes in the box.
Out of the box
2- Chromed Door sills with Double sided adhesive on the backside
2- Light strips, with relays and connectors
Step one:
Remove OEM doorsills,
These are a little difficult to remove, try pulling up at a couple of different locations as to not distort the doorsill.
Step Two:
Remove the Vertical Cloth covered trim piece off the rear of the doorsill
Step Three:
Open the plastic cable tray near the rear
Step Four:
Locate the switch wire (Ground) Brown with a Blue strip.
Step Five:
Locate the thick Red wire in the wire tray.
Step Six:
After locating and verifying that the Brown wire with the Blue strip is the correct wire. (Check this with your voltmeter. When disconnected the windows should roll up the last half inch. Cut and splice the Brown and blue wire with the Black (Ground) wire from the Illuminated light strip. Either solder them together or twist them and then cover wire splice with either heat shrink tubing or electrical tape.
Step Seven:
Cut and splice the Red wire from the cable tray and the Red wire from the Illuminated strip. Verify that this is the 12volt power source. This should be hot all the time.
Cover the splice with either Heat Shrink Tubing or electrical tape.
Step Eight:
Check that the light stays illuminated while the door is open.
Check that the light goes out by pressing the door button in the door jam.
Step Nine:
Place the excess cabling in the cable tray. Close the cable tray covers.
Re-install the Vertical Cloth covered trim piece
Step Ten:
Remove the clear plastic cover from the Illuminated strip.
Remove the two small strips of red plastic from the window area of the new doorsill
Place the Illuminated light strip over the “AMG” window (Light side down)
Press firmly on the light strip along the double-sided taped area to secure the light strip to the panel
Remove the remaining Red plastic cover from the backside of the Door Sill. Place the doorsill over the door jam and press firmly. Wipe clean and your done with this side repeat process for other side.
Finished product
Repeat for each door
Caution wire colors may vary vehicle to vehicle. Use the DC Voltmeter to verify that the wires you are going to splice are the correct wires.
(Warning you are attempting to modify your vehicle, you are taking on this task at your own risk)
Old Apr 29, 2003 | 07:07 PM
O-Dawg's Avatar
Tim,
Can you please send me the pics? I'm going to attempt to install my own this weekend.
omeshc at citrix.com
Thanks!
Old Apr 29, 2003 | 08:08 PM
Arnee's Avatar
Cayenne GTS, Cayenne Turbo
Installation for an SLK is different and more involved than the other cars, FYI. It's real easy for the other cars.
Old Apr 30, 2003 | 09:54 AM
CLKguy'01's Avatar
2017 C3004MATIC Sport, Obsidian/Blk, Prem 04, Pano and 2012 ML350 4MATIC Iridium Silver/Blk, Prem 01
Tim.....
Can you please send me a copy of the pics also?
I'm going to attempt to install over the next month or so...
thanks for taking the time to write up the instrucutions ....
my email address is:
fpro@***.net
Thanks again!
__________________
Old Apr 30, 2003 | 11:13 AM
Timster's Avatar
2011 GL450
You have mail!
Old Dec 21, 2003 | 04:40 AM
marksatex's Avatar
04' E500 w/Appear. PKG, Panorama Roof
illuminated sills
Please forward the pic to me also- Doing a 04 E500 the next week or so...
Thanks !
Old Dec 21, 2003 | 06:57 AM
Renn 208's Avatar
Re: illuminated sills
Thanks !
Tim's DIY should not apply to you
Old Jul 21, 2004 | 03:27 PM
thkingofcars's Avatar
Thumbs up
Tools needed:
Out of the box
Step one:
Step Two:
Step Three:
Step Four:
Step Five:
Step Six:
Step Seven:
Step Eight:
Step Nine:
Step Ten:
Finished product
Great instruction you gave for the wiring on the CLK55! Can you do the same for a 2003 E55??????? If so I’m in direr need. Hope to hear from you
Old Jul 21, 2004 | 04:51 PM
CLKBSVegas's Avatar
a Black
where do you get them and how much?
Old Jul 26, 2004 | 05:55 PM
mtimmy's Avatar
W208 55 & R170 230
Yep., exactly what I want to ask.,. where you guys get them.,., and how much?
Old Jul 26, 2004 | 07:17 PM
Chappy's Avatar
AMG
Try formymercedes.com or ebay.......about $150
Old Jul 27, 2004 | 01:52 PM
NJCLK430's Avatar
clk 430 desgno
illuminated sills
tim
can you please send me a copy of the picture install of the sill , also will the install be the same on a 2001 430 coupe.
thx for the help , my email is nehp94@yahoo.com
neh
Old Jan 11, 2005 | 10:11 PM
WaveyKat's Avatar
Something Slow
hi tim is it possible for you to send the pictures on how to install the sills please thank you ........waveyKat@msn.com
Old Jan 12, 2005 | 03:41 AM
carlssonW208Rs's Avatar
CLK320
trimster
do you mind mail me the instruction with picture as well
fergus_46@hotmail.com
thank you friend
