This light comes on every time I start the car. Power steering level is good. I am not sure what is wrong. The car drives great, no noises, no leaks I can see. Can this be a bad sensor? Also, the light displays what looks like a steering wheel and the oil symbol. Any ideas?
Hydraulic oil and a steering wheel? You have the older style display, and I don't know what those warning lights look like. On a new display
- If the adjustable telescopic steering column isn't locked, that will display a steering wheel, but there is no oil involved.
- The brake fluid warning looks like a wheel. If the fluid is low, the pads may be worn as well (the fluid level in the reservoir decreases as the pads wear).
The waring light is comes on when you first start the car on the dash board center display. The display says " hydraulic oil then has in the middle what looks like the MB oil symbol and on top looks like a circle with two lines coming fom the middle to the edge like a steering wheel. Leavel is on the other side of the symbol.
This is a 99 maybe thats why it is different. Still I have checked all fluids and breaks look good. Could this have something to do with just replacing the breaks? Any ideas would be helpful and thanks MarcusF for the reply!
