for those who replaced Mass Air sensor...
Old Nov 22, 2010 | 02:44 PM
krayzie_e99's Avatar
2000 CLK 320
my air mass flow sensor needs replacing. already have the new part and know its fairly easy to do but in addition to replacing the sensor, does anything else need to be reset?? or do i just plug in the new sensor and im good? please help me out, thank you
Old Nov 22, 2010 | 02:51 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Plug it in and drive.
Old Nov 22, 2010 | 06:36 PM
gregory13lil's Avatar
2000 CLK430
Just like DYNO stated...car will reset itself over time.
Greg
Old Nov 24, 2010 | 02:34 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Very easy DIY......only needs a screwdriver and 10 minutes time.
If this caused the CEL to come on, it will turn off after 3 cold starts.
If you're due for a state emissions inspection, some OBDII senors will need to reset to a 'ready' condition, which will take a couple of hundred miles of drive time.
Old Nov 24, 2010 | 11:32 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
plug and drive, if it was not installed right, the engine light will come on and means air is leaking out.
make sure its tight and snugged good
Old Nov 25, 2010 | 07:00 AM
cindyclk's Avatar
Only mistake people make is not seating the air filter intake onto the MAF...other than that, it's plug and go.
Old Nov 27, 2010 | 03:33 AM
2000 CLK 320
thank alot guys! guy at indy shop was tryn to charge me 150 bucks to "supposedly" reset it. i will plug and go, thanx again
Old Nov 27, 2010 | 11:28 PM
2000 CLK430
All he was going to reset was the error code and even that goes away on its own after driving it for a while. The only issue would have been if you were getting the car smog inspected soon after. In that case it would have been beneficial to get the error removed...but at 150 I would have found someone else to do it. Glad we could help you out!!
Greg
Old Nov 28, 2010 | 04:15 PM
Johnpidge's Avatar
W208 CLK55
Takes about 3 mins to remove the error code with a Star thingy (if it comes up) $150 - so thats ish £100 for 3 mins work or £33 per minute - hmmm - I'm moving to the States thank you
