Does anyone know if 18 inch c55 rims will work?
Old Dec 12, 2010 | 06:34 PM
rrich49132's Avatar
2005 c55
Does anyone know if stock 2005 C55 rims will fit on a W208?
Specifications:
Diameter: 18"
Front Rim Width: 7.5"
Front Rim Offset: ET37
Front Rim Mercedes Benz AMG Part Number: # A
225/40's
Rear Rim Width: 8.5"
Rear Rim Offset: ET30
Rear Rim Mercedes Benz AMG Part Number: # A
245/35's
Old Dec 12, 2010 | 07:56 PM
dlbehrns's Avatar
99CLK320,
fronts should work but I don't know about the back. tirerack.com can tell you and could recommend the right spacers to make the rears work.
Old Dec 13, 2010 | 02:49 PM
mint's Avatar
2013 FIAT Abarth 500
He won't need spacers; spacers effectively LOWER the offset, and I can tell you that 30 is plenty flush enough, albeit on the aggressive side.
However, you will need probably 5mm spacers on the front to make the fronts and back match as far as being square with the fender.
Old Dec 13, 2010 | 07:41 PM
err0neous's Avatar
02 CLK 430 Coupe
Specifications:
Diameter: 18"
225/40's
245/35's
Yes these will work perfectly. I have the same size and offset wheels on my car.
