Suspension question?
Old Jan 6, 2011 | 09:25 PM
RickTheRuler727's Avatar
'99 CLK320, '91 BMW 325Ic
I recently had a sub box installed, and it's weighing down the rear, so I want to lower the front to even it out. Can I just drop the front, and leave the rear stock, or is this a bad idea? I have an Eibach Pro kit that I'm planning on using, and I'm thinking if I install the rears it'll sag lower in the back due to the weight of the subs... TIA...
Old Jan 6, 2011 | 10:58 PM
dlbehrns's Avatar
99CLK320,
You are probably right. Depending on what number spring pad you have you may be able to lower the front end by installing a #1 spring pad. you can get them from the dealer, just ask for the E model #1 spring pad. The difference between the #5 and the #1 is .67 inches. how much do you need?
Old Jan 7, 2011 | 11:47 AM
It's only 3/8 of an inch lower in the back than the front, but there is so much fender gap in the front that it appears to the eye to look far worse...The springs I bought are supposed to lower it 1-1.5 inch, so I figured I'd just do the fronts first , and see how it looks, and rides first before messing with the back...
