Need help please. Wheel bolt for spare wheel.
Old Jan 25, 2009 | 02:04 PM
QB320's Avatar
Hello Everyone,
I have a 98 CLK320 and in need of some information. I'm looking for the part number for the Wheel bolts for the spare wheel since they are different from the stock wheel bolts. Any help is greatly appreciated.
Thanks in advance.
J
Old Jan 25, 2009 | 03:31 PM
hhseouljah's Avatar
2001 CLK 55
wheel bolts should be the same regardless of using the spare wheel or oem alloy.
Old Jan 25, 2009 | 07:03 PM
Serndipity's Avatar
2001 CLK320 Cabrio
[[I'm looking for the part number for the Wheel bolts for the spare wheel since they are different from the stock wheel bolts]]
I'm sorry that I don't have the specific answer you're looking for.
On my 2001 CLK 320 Cab; the spare wheel very different (steel vs alloy). It is thinner and requires shorter bolts (which were included in a plastic bag with the spare).
In this case, it's probably best to call the parts department at one of the dealers for the inforation.
Old Jan 25, 2009 | 08:19 PM
gregory13lil's Avatar
2000 CLK430
They are definitely a different size as I have mine in a plastic bag right next to the spare tire. I got it from the dealership for about 10 bucks or so. I would give them a call in the morning.
Greg
Old Jan 25, 2009 | 09:03 PM
hhseouljah's Avatar
2001 CLK 55
ah, never knew. my bad.
Old Jan 25, 2009 | 11:37 PM
sfclk's Avatar
1999 CLK320
i dont use spare wheel lugs. didn't notice any problems when i needed to use the spare.
Old Jan 29, 2009 | 04:36 PM
QB320's Avatar
Thanks for all the responses.
I tried my 2 local dealers and they can't seem to find the correct part. Would it be possible for someone to take a pic of the bolt so I can show it to them.
Thanks again.
J
Old Jan 29, 2009 | 06:47 PM
deyainrdy4ds's Avatar
w208
ya i dont have an answer for the part # or anything but i know ive been fine with the normal lugs that bolt up my 430's AMG rim...... i dono if it may be different for 320s? ......but the normal lugs are fine for the spare...n trust me ive used that spare a lot and no problems...
Old Jan 7, 2011 | 12:09 PM
IJMacKay's Avatar
CLK 320 Coupe
Thumbs up Spare wheel bolts - CLK
There is a significant difference between the stock OEM alloy bolts and the spare rim bolts. The stock bolt for a 320 is a 12 X 1.5 X 40mm, would be a ball seat and the 40 mm is measured fro the shoulder to the end of the bolt.
If you need bolts, best thing to do is call a shop that sells a huge selection of custom wheels for high performance vehicles. Case in point...... I was installing a Mercedes rim with winter tires on it, but I needed longer bolts as my 320 has AMG 18 summers on it. Dealer quoted me $27 a bolt......called the wheel guy and took a rim down to him, he had bolts in stock ($3.95 a piece - chrome bolts), and dry fit the rim to make sure it was perfect.
This will also weed out whether you need a conical or ball seat for the spare.
