Window bounce
Old May 6, 2003 | 08:47 AM
robk115's Avatar
Window bounce
How many times should it take mercedes to fix a bouncy window problem, they have had my car 3 times now for this problem. when the windows get wet, they bounce up and down while going up or down... has anyone else have/or had this problem? and what did they do to fix it?
Old May 6, 2003 | 03:17 PM
Josh K's Avatar
Tesla Model S
I've had this problem, too. Does it seem to be getting stuck on something? Or is it simply bouncing? If its simply bouncing, the memory on the control unit is probably messed up and when that happend on mine, they replaced that unit. I'm not exactly sure what part that is, but I'm sure MBTech208 or mmgrad could be of much more help. ;0) Good Luck
Old May 8, 2003 | 08:47 AM
robk115's Avatar
they are just bouncing, its both sides and they make noise when they go up and down, but only when they are wet, and apparently mb cant spare the water to put on the windows to see the problem....
Old May 8, 2003 | 09:35 AM
Pffelan's Avatar
CLK 430 Coupe + MGF + 1980 Camaro
"they all do that mr ffelan" is all my dealer said
Old May 8, 2003 | 02:58 PM
whiteyford's Avatar
When the rubber gets wet it tends to get sticky you need to have the rubber lubricated to keep it smooth. I'm not sure what to use because my detail shop does it for me. I would assume anything that can be used on a rubber surface that acts a a lubricant should work just fine.
Old May 9, 2003 | 02:50 AM
Supra's Avatar
CLK320 & SLK230
I got this problem too , so annoying
and it is even worse when windows going up
Old May 9, 2003 | 02:52 AM
Supra's Avatar
CLK320 & SLK230
well , i never asked about it in my dealer , but i dun suppose they would give me this kind of answer ..........
