Cabin Air Filter
Old May 8, 2003 | 12:06 AM
cgmike10's Avatar
CLK320, ML320, 300TE
Cabin Air Filter
I just changed my cabin air filter yesterday and I wish I had a picture of the old one. I dont know how leaves, dirt and pollen got in there but they certainly were. The filter was also black, and, to make things worse, the assembly that the filter goes into was filthy dirty discusting. Kinda like brake dust on rims. Cleaned it out with fantastic and water.
Results were noticeable almost immediately. The airconditioning worked much better (although maybe it was just in my head) and it pushed more air more quietly. Does anybody know if the ML or a w124 has these filters?
Old May 8, 2003 | 07:15 AM
lionj's Avatar
Hey Mike,
Can you tell me where the carbin air filter is located and is it easy to replace? thanx in advance.
Old May 8, 2003 | 03:06 PM
russdog's Avatar
2014 ML350 BlueTec
Instructions
Can you post some instructions on how to change the filter. After reading your post I feel I should check mine! Ho much are new filters? Can they be cleaned?
Thanks!
Russ
Old May 8, 2003 | 08:10 PM
cgmike10's Avatar
very simple
chaning the filter is very simple. Just unscrew the plastic panel by the passenger side footwell, and look for a rectangular black box with 2 white sliding locks. Slide the locks off, take out the filter, but observe how it sits in the assembly. Wash out the inside with a damp paper towel use fantastic and or lysol and then use water. Then pop the new filter in and ur done.
After seeing ur filter, you wont want to clean it. The filter cost me around $40 at the dealer.
Old May 9, 2003 | 12:37 AM
ljcook's Avatar
2001 CLK55
Here is a link to the instructions in Filter PDF
Old May 9, 2003 | 09:27 AM
russdog's Avatar
2014 ML350 BlueTec
Thanks for the info!
Thanks!
I will take a look at it this weekend!
Russ
Old May 9, 2003 | 02:54 PM
tomtomtomtom's Avatar
02clk55///2010GLK350
Thanks! I have a job for the weekend too
Old May 10, 2003 | 02:27 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Do you know of any other tech bulletin/guides like this one for the CLK? the Bosche site didn't have any other DIY guides for any other parts/accessories
Old May 11, 2003 | 07:14 PM
ljcook's Avatar
2001 CLK55
Try a subscription to AllDataDIY.com
Old May 12, 2003 | 12:57 AM
mmgrad's Avatar
Thanks! I think i'm gonna give that a try, just to see what they have to offer...
Old Aug 8, 2008 | 06:05 PM
TomWR's Avatar
E320 1995
W124, 1995 E320, cabin filter changeout?
Does anyone know how to change cabin filter for this '95 please? Had it done over a year ago by local, trustworthy, shop but would like to do it myself; can't be all that difficult, just where and any necessary advice too.
My shop charged $30.56 for a "microfilter sold as set". Labor was lumped into other work for that day.
Thanks.
Old Aug 15, 2008 | 12:42 AM
rjlawlor646's Avatar
2001 CLK 320
make sure you know exactly how it sits before you pull it out..i just pulled mine out without looking and it took forever to get back in, then i felt like an idiot when i figured it out..
Old Aug 15, 2008 | 05:09 PM
cindyclk's Avatar
Just check the DIY sticky at the top of this forum page...scroll to #21 and you have all the pics and info that you need....15 min job
https://mbworld.org/forums/clk-class-w208/120446-w208-how-s.html
Old Aug 16, 2008 | 04:53 PM
enyce284's Avatar
1998 CLK 320
Smile
i just did mine today the a/c blows so much harder and colder i was shocked.....the filter only cost me $25.00 and it was well worth the money and is an absolute DIY it only took me less than 5 minutes
Old Mar 18, 2009 | 12:46 PM
ljcook's Avatar
2001 CLK55
Link seems to have gone away so here is the PDF file.
File Type: pdf
