Hidden features
Old May 9, 2003 | 09:53 PM
whiteyford's Avatar
Hidden features
I own a 2001 Mercedes C. L. K. with climate control. I'm not sure if anyone has posted this yet but I thought is might be of interest to some people out their. If you hold down the restore button on the climate control for approximately five seconds a series of numbers will show up. The numbers on the left correspondence with different features of the car that are represented with the numbers on the right. The numbers on the left I believe are between 1 and approximately 43. I'm not sure what every number means but some of them are for RPM's #21, engine temp # 6, another is for battery voltage #24, for those of you who are into car audio, the higher the voltage the more you can get out of your stereo system, and actual ground speed, just in case your odometer is off. I noticed that mine was off slightly. I'm not sure which number it is but you can figure it out while your driving, maybe bring someone with you. All you need to do is push the auto button on the top or the bottom to scroll through the numbers. Try it out and you'll see what I'm saying I will post pixs.
Old May 9, 2003 | 09:55 PM
whiteyford's Avatar
pic 2
pic 2 voltage
Old May 9, 2003 | 10:22 PM
RJC's Avatar
RJC
Various
Very cool...never knew about this. My 208 is gone and I'll try it on my 209.
Old May 9, 2003 | 10:25 PM
tery's Avatar
CLK320
can i set the voltage higher ?? can i set any numbers ?
Old May 9, 2003 | 10:33 PM
whiteyford's Avatar
The voltage is based on the output of the alternator to the battery it will go higher when your driving and other accesories are off. If your concern is for the stereo equiptment then use a stiffining cap. 1 farad should work. I'm not sure if any of the numbers can be adjusted. I think its just a display.
Old May 9, 2003 | 10:40 PM
tery's Avatar
CLK320
icic thanx!
i m getting 14.5 volt now i whish can go higher hahaha
i m trying to figure out what other #s stands for
Old May 9, 2003 | 11:52 PM
Mach430's Avatar
Excellent post! Which number represents the speed? I could not find one that was close to my mph.
Old May 10, 2003 | 01:09 AM
J Lucas's Avatar
What a great discovery........! Did anyone else know about this?If so is there a list of what each number stands for?
Old May 10, 2003 | 02:20 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
that is pretty cool... i guess MB makes everything easy access so they don't have to use their diagnostic computers that much....
i wonder if the dealer would actually tell you what each display meant?
Old May 10, 2003 | 03:01 AM
whiteyford's Avatar
Ben,
# 21 should be ground speed. Either that or #20
Old May 10, 2003 | 04:00 AM
Mach430's Avatar
Thanks,
I'm either off by A LOT, it isn't in mph, or they designate something else. Does it update in real time, or do I need to maintain a constant speed for several seconds to get a correct reading?
Thanks,
Ben (going 80 when the speedo says 30 )
Old May 10, 2003 | 04:27 AM
tery's Avatar
CLK320
i think #21 is RPMs
Old May 10, 2003 | 11:43 AM
KU104's Avatar
Awiner did a post on this in the CL forum...Look for A/C dialog mode in search... it gives you a list of all the numbers and what menu they pull up I thought you guys knew bout this from before...Can someone tell me if it works in the 2003 E-Class (W211)?
Old May 11, 2003 | 10:34 PM
911Jose's Avatar
2001 CLK
If anyone found AWINER's post, please post a link to it here. Cant seem to find it. I'd like to know all the functions.
Old May 11, 2003 | 10:54 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
This is way old news... you can even find out a lot about it if you do a search on the net.
The climate control also has a diagnostic mode where the car error codes can be viewed and cleared.
Here's a list of the meanings of the various settings. Not all cars will have all values. Values of temperature are always in Centigrade; values of speed are always in KPH.
Code:
01 = In-car temp sensor
02 = outside temp sensor
03 = left heat exchanger (heater core) temp sensor
04 = right heat exchanger sensor
05 = evaporator sensor
06 = coolant temp
07 = refrig.  pressure in bar
08 = refrig temp sensor (23*9 = 23.9deg C)
09 = nothing
10 = Blower control voltage (great for evaluating blower controller problems)
11 = emissions sensor (B31) e.g. 3.1 = 31.v
12 = sun sensor 4.2 = 4.2v
20 = aux fan control 6.1 = 6.1ma (max 10ma)
21 = engine speed
22 = vehicle speed
23 = Circuit 58d e.g. 99 = 99% of battery voltage
24 = BATTERY VOLTAGE e.g. 12.5 = 12.5v
30 = left rear air conditioning heat exchanger temp sensor (not all vehicles; obviously)
31 = right side
32 = rear evap temp sensor
33 = blower control voltage rear 0.8(MIN) - 6.0(MAX)
34 = left rear temp selector
35 = right side
38 = software status e.g. 37 rear air conditioning
38 = hardware status e.g. 37 , rear air conditioning
40 = control module version software status (?)
41 = control module version menu hardware status
42 = control module variant code 1st number
43 = variant code second number.
-s-
Old May 11, 2003 | 11:03 PM
Timster's Avatar
2011 GL450
Thanks for posting the list!
It might come in handy some day?
Tim
Old Sep 9, 2007 | 09:19 PM
newguy2008's Avatar
CLK 55 ///AMG Cabrio, ML63 ///AMG
That someday was today for me.
Thanks.
Tim
Old Sep 9, 2007 | 11:00 PM
deyainrdy4ds's Avatar
w208
nicee..never knew about this..ne1 know if it works on 99s tho? and what exactly is the 'restore' button?
Old Sep 9, 2007 | 11:29 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
it does work on 99s but not all the options...its the REST button on button left side i believe?
Old Sep 15, 2007 | 07:30 PM
w208
aight kool ill give it a try
Old Sep 16, 2007 | 09:29 PM
Idle Swede's Avatar
01 430 CLK, 85 RR Silver Spur, 90 Bentley Turbo R, 93 FLSTN
Great info, thanks a lot........
Old Sep 18, 2007 | 03:07 AM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Cool
https://mbworld.org/forums/clk55-amg-clk63-amg-w208-w209/193466-engine-temps-w208-clk55.html
