AC Compressor / turning real easy with finger with no resistance
As always thanks for your help and advice.
-Ac worked fine in 09.
-Last year AC didnt work. Charged up with Freon and work great all summer long.
-this year Ac blows hot after trying it for first time a few weeks ago.
-A mobile Ac guy came out and charged it up for me and still did not work. Recommened replacing the compressor.
-Took car to mechanic whos helped me before with my lincolns AC. he connected his machine said there was no leaks, however there was no ac. He then Charged it up and advised it was electrical and advised checking with a Stealership.
-Local mercedes shop, connected a device to computer, and removed th codes and ac started to work and the EC lihgt went off. They said that the compressor was making a lot of noise and recommended replacing it as well as the Temp and Pressure switch. (said they would charge $450 for labor to replace it )
-Ac blew cold for a day or so then quit. I tried it today and did not blow cold at all.
-I found a local shop with a compressor and will pick it up soon to have my mechanic replace it. unless you think it's something else.
- so here I am with the codes.
