Spring pads
Old May 15, 2003 | 04:40 PM
whiteyford's Avatar
Spring pads
This is something I don't know much about. Can anyone tell me what type of spring pads are require for Schatz springs. Would they be the same as the pads for H&R springs. And please make your answer in layman's terms.
Old May 16, 2003 | 12:52 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
spring pads are spring pads, you would use the same 'type' no matter what springs you use. MB carries spring pads ranging from 1 dot (thinnest) to 5 dot (thickest).
The thicker the pad, the more of the shock it will absorb, giving you a better, smoother, cushier ride. The thinner the pad, the bumpier the ride. Ride height is also affected by the pads.
hope this helps.
-danny
Old May 16, 2003 | 01:13 AM
whiteyford's Avatar
Thanks,
Perfect answer. That's what I needed to know
Old May 16, 2003 | 06:38 PM
whiteyford's Avatar
Are there any recomendations on which pads to use. I want the car lower but i would like to keep the ride reasonable. Your input is appreciated.
Old May 16, 2003 | 06:50 PM
mmgrad's Avatar
i believe my original pads were 3 front, 2 rear. or 4 front, 3 rear.
i later installed #1 pads on all four corners. i don't notice a harsh ride or anything... i think the difference is very marginal
the change will be much more apparent if you get rims in 18" or 19" cause the tires won't absorb much of the shock
Old May 19, 2003 | 06:16 PM
nickv's Avatar
Used to be a CLK430
Can I go with #1's all around on stock shocks? If so, how much of a drop could I expect??
Old May 19, 2003 | 06:19 PM
cgmike10's Avatar
CLK320, ML320, 300TE
H&R is definitely way to go
I put on my H&R springs. The ride is firmer, but still comfortable, and the car looks so much different and better with them on!
Old May 19, 2003 | 06:38 PM
mmgrad's Avatar
For me, the Brabus suspension (i believe) is rated at a 1.2" drop. While doing the suspension, I put #1 pads in, which put it at a final drop of 2". Therefore, i'm thinking every change in pad will result to an approximate .25" difference.
Not abosolutely positive though.
