Steering wheel vibrations
Old Apr 18, 2011 | 10:25 PM
00Mercedes320's Avatar
00 clk 320
I just had motor mounts and trans mount replaced and for some reason on D or R I STILL have vibration in the wheel (when at standstill) not as bad as before though. It seems like it comes and goes, when idling one second it will be fine, but the next it will shake and so on and so forth, my RPM's do not move nor is the car reving, it just shakes at different intervals. Also, it's only when it's completely idle. If I give it the slightest bit of gas it goes away? Any ideas on what this would be?
The motor mounts are Boge and the trans mount is OEM.
Old Apr 19, 2011 | 10:04 AM
Opal_CLK's Avatar
2000 CLK 320
dont understand what you are asking. how bad does it vibrate?
Old Apr 19, 2011 | 11:19 AM
00 clk 320
It vibrates just a little. Sometimes it is bad, but most of the time if i just "touch" the wheel I can feel it. but if I grab it and hold tight. You cant really feel them. I replaced the motor mounts and the trans mount thinking that would cure it. But, sometimes when I am at a complete stop, it wont vibrate at all. Other times, it will. So, I'm trying to figuer out whats going on. Any ideas? It only happenes when i am at a complete stop, and if I give it the slgihtest bit of gas, the vibration goes away.
Old Apr 19, 2011 | 11:23 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
i have the same issue I think it may be a bad spark plug wire. did you get your mounts replaced at the dealer or at leaset a place that uses OE parts?
Old Apr 19, 2011 | 11:41 AM
00 clk 320
Yes, everything was done right. at the right place and the right mounts. It's weird, sometimes if I have the steering wheel striaght, I get no vibrations, but if i move it to the right of left (standstill) I get vibrations? It cant be anything mechanical like a drag link or anything like that, because I am not moving. So, I am so clueless on what to do. Wouldn't a bad spark plug wire cause it to run crappy all the time, and not when I only have it at bare idle?
Old Apr 19, 2011 | 01:16 PM
insame1's Avatar
have you tested them. maybe it does happen above idle and you just cant feel it. also when I get a little lower in my seat and look at he rpm i can see it move ever so slightly. when was the last time you cleand you maf?
Old Apr 19, 2011 | 01:19 PM
slowsky's Avatar
2011 C63
same issue here too..think they all idle a bit off with age...possibly running too lean now? i've replaced just about everything from spark plugs, wires, cps, maf, gaskets, and 3 mounts.
could be plugged cat...maybe its time for some kleeman headers
Old Apr 19, 2011 | 03:32 PM
00 clk 320
No, When I give it gas, I can totally feel the steering wheel with no vibrations. I havent tried cleaning the MAF because normally with those, they show a sign of heistation and stalling. Not this kind of problem I am experiencing. Slowsky, are you having the same exact conditions as me?
Old Apr 19, 2011 | 03:49 PM
slowsky's Avatar
2011 C63
yes, same thing....i've just learned to live with it...feels kind of old school muscle car idle...at least that's what i tell myself...
Old Apr 19, 2011 | 05:14 PM
00 clk 320
YESSS THAT IT!!!!!! A muscle car idle. Where you can feel the engine moving along with the rest of the car. But a very soft muse car. Although the steering wheel shake has to go. I can't stand it. Anyone know anything I can do?
Old Apr 20, 2011 | 12:10 PM
mint's Avatar
2013 FIAT Abarth 500
- Change out spark plugs, wires if need be
- Clean the MAF
- When you said if you move the steering wheel to the left or right, the vibrations appear...could be something with the power steering?
Old Apr 20, 2011 | 01:43 PM
00 clk 320
When you first start the car, you know how it always revs a litte high in the beginning but drops down to idle. Well when it is in the high rev stage (normal when first starting a cold car) there is NO vibrations, but once it drops down to normal idle ( around 500-600) then the wheel starts to vibrate. Any ideas on what this could be. It's also in park too! But not AS bad. I changed the plugs last year. Along with cps. What would this tell me is wrong with my car?
Old Apr 20, 2011 | 02:08 PM
slowsky's Avatar
2011 C63
possibly fuel injector clogged? what about o2 sensors?
we have identical issues....by the way, this doesn't effect power...last summer i ran a 13.4 in the 1/4 mile and that's due to traction issues....
Old Apr 20, 2011 | 05:03 PM
insame1's Avatar
00Mercedes320 lust my 2 cents but you came here looking for help and shoot down everyone’s suggestions. It has been suggested to check pugs and wires and MFA but you seem pretty sure that this is not the problem but yet you have no idea what the problem is. I too am experiencing the same thing and have not found a fix. I did test my wires and notice the OHM load just slightly off. You might want revisit the items suggested to you and go from there.
Old Apr 20, 2011 | 05:51 PM
00 clk 320
Sorry, I'm not trying to shoot anyone's ideas down. I was just saying that I know it cannot be the plugs itself, because those were replaced last year. And the MAF "usually" doesn't experience these kind of problems. HOWEVER, it "might" be wires! Just because I have never replaced them. But, wouldnt the wires cause it to vibrate all the time? O2 sensors I havent check either? But, with doing a lot of research on this and benzworld.ord forum, I have not found that 02 sensors would cause it to vibrate at idle. The only thing I found that causes vibration at idle is mounts. Maybe the idle has to be raised just a tad? That's an idea?
Old Apr 20, 2011 | 07:05 PM
insame1's Avatar
I would at least test the wires. It is a good place to start and not to $$$ to fix as you can buy one at a time. I think there are 4 o2 sensors so it may be best to have that looked at by someone with the star system. If you used all OE mounts they should be fine. I have heard and read a lot of complaints about aftermarket mounts. As far as the idle I have 2 older Mercedes and on them I would consider it but haven’t yet. as for our cars I don’t know if it can even be done physically or if it is an ECU thing. I am going to replace my suspect wires and do a BG additive system to try and remove some carbon deposits and see if either helps. I too dont think it is the plugs in my car as I just replaced them about a month ago with denso irdiums.
Old Apr 20, 2011 | 09:48 PM
00 clk 320
Please post results of the car when you replace the wires. I am eager to see if that fixed it!
Old Apr 21, 2011 | 11:19 AM
insame1's Avatar
Will do. with any luck I can get them Friday when i go get my other parts and try to get them in Saterday.
Old Apr 28, 2011 | 04:41 AM
MRGROOVE's Avatar
98 CLK320
Hey Insane1, I too would like to know the outcome. I'm having the same issue, and have learned to live with it (sorta), but it is annoying.
Old Apr 28, 2011 | 11:09 AM
insame1's Avatar
still waiting for my parts. the ones that were ordered came in but they were the wrong ones so I am waiting for them to call me with the new ones.
Old Apr 28, 2011 | 04:14 PM
MarcusF's Avatar
2002 CLK430
O2 sensor input is used whenever the car is in closed loop mode. That's either at idle or at cruise. So it could be one of the primary sensors. I changed my O2 sensors twice last summer (the universals didn't quite work out) because they are normal wear items. You can check them, but the check will only tell you if they are way out of spec/faulty. If they are out of spec enough to ruin the idle, they may not appear to be completely bad when tested.
Other things it "could" be: It could be a lousy spray pattern from partially clogged injector (change the fuel filter regularly?). It could be a vacuum leak (is the MAF seated properly? (see my webpage) is the air cleaner assembly seated properly on the MAF? have you checked the vacuum lines?). It could be a marginal plug wire (those can be easily tested, and a complete set of Bosch wires is about $200).
*I think* raising the idle will mask the problem (and help wear motor mounts). My car idles at 400 RPM or so while stopped in drive. It's always idled at this speed and it does not shake.
