5x114 on a w208??????
Old Jul 27, 2011 | 11:56 PM
jbenz2001's Avatar
2001 clk 320
So as the title says 5x114.is it possible?if not then idk why do my lowenhart BR5s fit perfect on my clk?inside the rims they say 5-114 3 is that the same as saying 5x114?today I google w208 lowenhart BR5 and I saw a guy on our forum that bought the same wheels and had the same issue with the wheels saying 5-114 3.I drove the car today and it was smoother then all the rims I've put on the car since I got it back in 2007.it does have slight shake on the highway but noting really noticable unless your **** like me.from 1-10,id say a 1.can anybody explain this issue to me please thanks.
Old Jul 28, 2011 | 02:23 AM
desired_speeds's Avatar
2007 SL55 AMG
Mercedes bolt pattern is 5x112. The wheels' bolt pattern is 5x114.3. They fit because the difference in bolt pattern is only 2.3 mm apart. It means that each bolt hole is off by approximately 1mm. They will fit, but you get that slight vibration at higher speeds because the wheel is not 100% centered unless the wheels are hub-centric. People who run 5x114.3 wheels on a 5x112 hub typically use wobble bolts to make sure that the wheel bolts center the wheels onto the hub.
Old Jul 28, 2011 | 10:09 PM
dlbehrns's Avatar
99CLK320,
What is a wobble bolt please?
Old Jul 29, 2011 | 12:42 AM
jbenz99's Avatar
Sold 2003 CLK 500,2003 SL 500,2006 Acura MDX,1998 BMW M3 convertible
You can fit 5x114.3 wheels on 5x112 or 5x110 to 5x112. With these wobble bolts!
Attached Thumbnails 5x114 on a w208??????-varibolt1web.jpg   5x114 on a w208??????-dscn34485686334.jpg
Old Jul 29, 2011 | 04:39 AM
jbenz2001's Avatar
2001 clk 320
Wow I learn something new about mercedes everyday.I'm def gonna buy set of these asap.I'm come across the craziest deals on rims.by the end of the year ill should have my garage full of sets.I already 2 sets of lowenharts,a set lorinsers and my spare wheels tsw bremmas.
Old Jul 29, 2011 | 10:06 AM
toymr2trd's Avatar
*** kidding me.... never knew about these bolts.... haaaa
thanks for the info =-)
Old Jul 29, 2011 | 02:15 PM
dlbehrns's Avatar
99CLK320,
WHO KNEW! it looks like the top of the bolt moves/wobbles within the conical head, no?
Old Jul 29, 2011 | 03:50 PM
CLK55_NYC's Avatar
2001 CLK55,2003 CL55AMG,2003 E55,2004 CLK55,2011 E350
I almost laughed when i read "wobble bolts". Crazy!!!!
Old Jul 29, 2011 | 11:10 PM
jbenz2001's Avatar
2001 clk 320
Yeah the name is kinda now that I come to think about it
Old Jul 30, 2011 | 05:45 PM
VIPclk320's Avatar
CLK W208
if i had my 5x114x.3 wheels drilled ad the sleeves put in do i still need to run wobble bolts? or if you had the wholes drilled bigger you dont need wobble bolts?
Old Jul 30, 2011 | 06:07 PM
jbenz2001's Avatar
2001 clk 320
Hey what's up vip,I wouldn't think you'd need them if the holes were drilled precise but I would buy them so the rims would have a perfect fitment.im running 5x114 lowenharts with no problem.
Old Jul 12, 2015 | 01:04 AM
vsacco's Avatar
c280 w202
what length bolts would you recommend? I'm looking to use these on my w202 to go to 114.3 but don't know what length to get. thanks
