P0446 EVAP CLK320 1998
Old Oct 15, 2011 | 09:35 PM
A-JAY's Avatar
1998 CLK320
Exclamation P0446 EVAP CLK320 1998
Hello.
I have just bought a pre-owned CLK320 and the check engine light is on. I got it checked and found a P0446 Evap problem. They recommended that I should replace the vent valve (because it is clogged) and evap canister but the thing is I am just a student so is it possible that I can still drive with it? or will it do further damage to the engine? will the charcoal make serious harms?
I also have a question regarding "Lamp Deflective"...I replaced all light bulbs and reset the system but it is still on. The thing is, the previous owner put HID aftermarket headlights and I noticed they are 2 different brands. Does the CLK320 needs a balance for the HID? or does it have one integrated? do I have to put regular bulbs to get it to work? or is there a way to keep the HID and get rid of the lamp deflective message?
Thanks in advance and my main concern is about the evap problem.
Old Oct 16, 2011 | 12:46 AM
A-JAY's Avatar
1998 CLK320
over 150 views and no reply? what kind of forums is this lol
Old Oct 16, 2011 | 01:25 AM
MarcusF's Avatar
2002 CLK430
I don't know and I don't know. Most won't respond if they don't know because it doesn't add meaningful content. That and (1) weekends aren't the busiest periods because many are out doing things and (2) 3 hours and 10 minutes really isn't that long to wait for a response.
I could "guess", but these can be expensive cars when the wrong guess is made. I don't think it's an expensive guess, but I'd rather tell you how the system works and let you guess. As you fill the car with gas, vapors go from the gas tank, through a vent line, to the expansion reservoir. The fumes then go across another line from the expansion reservoir to the charcoal canister. The fumes then go from the charcoal canister to the purge control valve, which at times, receives a vacuum from the engine. That vacuum clears the fumes.
Old Oct 16, 2011 | 12:51 PM
A-JAY's Avatar
1998 CLK320
I was just joking about the responses. Thank you for the brief explanation, I thought the charcoal will eventually go through the gas tank. I guess it'll be fine then.
Old Oct 19, 2011 | 01:25 PM
CLKBOB's Avatar
1999 CLK 320
Every so often I get the lamp defective warning. Nothing wrong with the lamps. My right rear light assembly connector works loose just enough to trigger the warning and I just push it back into place. You may want to check your connector assemblies. Hope this helps.
Old Oct 19, 2011 | 03:41 PM
A-JAY's Avatar
1998 CLK320
The message shows up once I hit the brake pedal, although the rear lights all working properly (except the additional ones attached to the trunk lid). The previous owner put the 7225LL SYLVANIA bulbs on the brake lights. I noticed something funny about them because I don't see a difference when I hit the brake (they don't light up much more). So if I didn't have the brake light bar on the rear windshield then whoever driving behind me won't notice when I hit the brakes. Maybe I need to put different bulb brand although the SYLVANIA is the recommended one on the internet for the CLK320.
Thanks.
