Dismantling the dashboard
take off the radio, the ac control, the wood trim around it, the pocket under the radio, the wood around the shifter(the one with the switches on it
then you will notice that the ashtray is held on the center consul vi two philips screws on the bottom of the wood grain pece that just removed, remove thos screws and pull the ashtray out and disconnect the wire from the lighter behinde the ashtray.
then open the armrest/storage box, you will see a t shaped plastic that sits right under the storage push bottons where the cup holder meets the atorage box, pop that plastic off and you will see two phillips screws, remove those as well.
next in the ac control area there are two screws that are holding the top leather trim piece of the center consol against the top dash, they are gold screws, one on each side, remove those and then thee are two clips that are right by the screws, pull n those very gently and you will notice that the top leather trim will come off.
nect on each side of the foot area there are two air vents, remove those by turning the pastic screw on them half way and they will come out.
next open the storage box/armrest and remove the carpet piece on the bottom and there are two screws under it, remove those as well.
on the passenger side and driver side remove the under dash covers. big plastic piece with 3 screws on holding each side in.
now gently pull the center consul back toward the rear seats and then up and it will come right out.
1. The wood trim around the ac controls, does it easily come off if I pop it out with a flat screw driver or a panel removal Tool? Pry from any Side?
2. The wood trim surrounding the shifter, pry and pop out style as Well? Any breakable teeths I should worry About?
3. If I successfully remove the ac controls plus the wood trim, will I be able to take out and replace the center air Vent? My center airvent does not swivel anymore hence I have to replace it.
Thanks again vip. Oh by the way OT here but the Clks out of the shop now after a month and a half now with your beautiful Skirts! Will post some pix soon :-)
the wood aroud the shifter just grab a edge by the ashtray or the cup holder and pull it up.
in order to remove the top leather trim piece you do have to remove the ashtray assembly
the wood around the ac control is very easy to remove, take off the ac control and disconnect the wires, then pull out and up on the bottom of the woodpece and it comes right out.
How do you remove the the top leather trim piece only? I was fiddling with the center console cup holder/box and took out the lid, now the lid locking mechanism and its springs are between the side panels covering the center console and the box itself, it seems that i need to remove the leather trim and unscrew the cup holder box base to re attach locking pins and springs
... any advise well be very much appreciated...
Thanks,
Sirswift93
