Transmission Issue
Old Apr 3, 2012 | 01:00 AM
kboat's Avatar
CLK 320
Transmission Issue
I have a 1999 CLK 320. My issue from time to time is my car feeling like it falls out of gear sometimes around 65 MPH. It doesn't happen every-time I drive it but on the days it does it it'll keep doing it until the car sits for awhile... I can be going along just fine then it feel like it drops a gear & the RPM's will raise to about 3500-4000. I can give it more gas & speed up some & it'll go back to normal! When I had it scanned there were no transmission codes but it seems to me if it were the transmission it would do it every-time I drove the car. I only drive it every now & then but on the days I drive it more is when this happens. I can allow my car to sit awhile & it drives just fine. This has made me start to question is maybe it does this when the filter loads up with trash. PUZZLED
Old Apr 22, 2012 | 10:09 AM
ththomasjr's Avatar
W208
Transmission
It sounds like it could be the transmissions valve body. I had the same problem, when the car is cold the transmission shifts with no problem. When you drive for a while it starts slipping and hard shifting. Replaced the valve body and the car shifts like new again.
Old Apr 22, 2012 | 11:02 PM
kboat's Avatar
CLK 320
I 100% thank you for your reply! I will be jumping right on investigating if this could be my issue! Is this an expensive ordeal?
