Whining noise
Old Apr 12, 2012 | 02:09 PM
Ugur13038's Avatar
1999 clk320 v6 coupe
Whining noise
Hi i have 99 clk320 when it's cold engine and when i start runing the 1 gear i have whining noise specialy i can hear that noise 0-30 anybody idea thanks but shiftings are ok tranny is very good but the whining noise it's killing me.
Old Apr 12, 2012 | 04:03 PM
mint's Avatar
2013 FIAT Abarth 500
where's it coming from?
if it's a squealing sound coming from the dash area it's probably the serp belt slipping or one of the drive pulleys is dying.
if it's a whining sound coming from the tranny...that can't be good. when was the last time you flushed the tranny and torque converter?
Old Apr 12, 2012 | 05:17 PM
Ugur13038's Avatar
I just bought the car one months ago i did not flush the tranny yet
But sounds not from the dash area kind a tranny or under the engine
Sorry where is the serp belt or drive pulley any pictures?u mean engine belt the rubber one
Old Apr 12, 2012 | 09:35 PM
Ugur13038's Avatar
I change transmission oil and flush but still i can hear the noise thanks
Old Apr 13, 2012 | 12:35 AM
Pancho's Avatar
2000 CLK430 Cabriolet
The serpentine belt is the main belt. It is at the front of the engine, and turns several pulleys that provide power to several components under the hood--power steering; alternator; etc. There are also "idler" pulleys that do not provide power to anything, but they are necessary for guiding the belt.
You need to determine if any of the pulleys are making a whining noise. If the idler pulleys are making a noise, then these are the least expensive to repair. These pulleys have sealed bearings, and when the bearings fail, they make a whining noise. You can use a stethoscope to try to isolate the noise. You can also use a long wooden dowel to transfer vibration and noise to your ear. Be careful, because if the dowel touches a spinning pulley, then the dowel will be pushed into your brain, and that will make things very difficult for a long, long, time.
In short, try to determine if the whining noise is coming from a pulley. A whining noise usually comes from a spinning or rotating part.
Best of luck.
Old Sep 24, 2012 | 01:47 PM
wnycec's Avatar
2000 CLK 430
How to...
Anyone have a good link to help remove the serpentine belt? I would like to install a new one I bought but my seach is not coming up with anything easily.
Old Sep 24, 2012 | 02:56 PM
jserio's Avatar
2004 CLK500 Cab
The whining could also be coming from the differential ( or Rear End ). When trying to hear where a noise is coming from I've gone into a big empty parking lot and rolled the windows down, opened the hood to the safetly latch, and drive it around up to like 20 mph. If you do this it should give you a good indication on where the noise is coming from.
