Intermittent non start
Subscribe
Jul 29, 2012 | 01:56 PM
This is a stock 01 clk430 with 194000+ miles.
I did a top side oil change on my car and then next morning it cranked but did not fire. It continues to crank until I turn the key back to position 1. I tried the key again and taped the gas and it fired up and ran fine. I took the car around the block, came back to my house, turned it off and restarted with no problem. Let it sit 15 min and it started and immediately died. Hit the key and tap the gas and it started right up. I then drove the car about 10 miles and left it there for about 2 hours came back and same thing happened. Started then died. Restarted with a tap of the gas. At this point I am thinking fuel pump relay. Later that night I was going to dinner and the car would not start at all. Went out this morning to see if I could figure it out. Hit the key and it looked like the battery was week (dimming the lights). Hit the key a second time and pumped the gas and it started.
I have with in the pas 6 months changed the CPS with a part from the dealer. Spark plugs (Denzo iridium) new battery from the dealer. I always use premium gas. Regular oil changes with mobile 1 0-40. Also I took the air cover off and looked for anything that could have come loose.
This car has not given me any problems except the CPS up till now. There are no trouble codes. When it fires it drives like normal. No flat spot throughout the entire range of the throttle. Idles well and does not die while running. Temperature does not seem to be a factor. Sorry for the long post but I’m stumped and want to give you all some info. Any help would be great.
Reply 0
Jul 29, 2012 | 10:08 PM
Nothing? Between the 3 sites I posted this on i have over 700 views and no replies. Either this is a really good one or I have been black balled
Reply 0
Jul 30, 2012 | 02:00 AM
That's an odd one unless the cps has gone again but I thought it was hot starting when it fails, last thing that happened was the oil change which I can't see how that would effect anything, have you tried the oil level check function in the dash, just in case it thinks something is wrong long shot I know, but then it would be telling you,
Reply 0
Jul 30, 2012 | 04:24 PM
going to try the brake stop switch today and see if that does anything.
Reply 0
Jul 30, 2012 | 04:30 PM
Sounds like an electrical mystery to me. Old hondas have problems like this due to the PGM-FI relay which have failing solder joints. It could be a bad sensor, battery, loose ground somewhere, relay... who knows. Maybe if you take it to the dealer their super computer can identify some fault?
Reply 0
Jul 31, 2012 | 11:33 AM
So last night I took the car to an indy here in town. The star reader had no codes relating to the issue as far as we could tell. Also the fuel system card could not be read at that time.
This morning the car started and I drove to work with no issue. I dropped it back at the indy and they are going to give me a call when they have it figured out. Right now they think it is the cam position sensor. Not the crank position sensor. We will see.
Reply 0
Aug 1, 2012 | 04:33 AM
Crank Sensor very common on 430 and 55 ?
Reply 0
Aug 1, 2012 | 11:26 AM
the one in the car is less than 6 months old. Had it at the shop all day yesterday and it worked fine. Started right up this morning with no issue. Are these cars so cool they fix them self? lol. We will see what happens.
On another note the guys at Folsom Werkstatt are AWESOME. If you are in the Sacramento area this is the place to go.
Reply 0
Subscribe
Currently Active Users (1)
