19" rims fitment
Old Feb 26, 2002 | 11:40 AM
CLKqueen's Avatar
19" rims fitment
I just converted last week from Japanese to German (Prelude Type S -> CLK320) and I'm very happy with this move!! My first planned upgrade deals with changing my nasty stock 16" alloys. Is it taboo to stick Japanese rims on my CLK? I have a set of 19" Racing hart C-5 3-piece rims in my possession, but the lug pattern is different (5 by 114.3mm). My question is...how well can CLK hold 19s (8.5" front and 9.5" rear) ? Also, is it advisable to use wheel adapters to fit my C-5s? If so, where and how can I get a hold of such adapters? Which lowering springs should i consider with 19s? I just want to get rid of the wheel gap a little and not go too crazy.
Old Feb 26, 2002 | 12:47 PM
nsevert's Avatar
CLK 430
19x8.5 and 9.5 will fit as for springs your best bet is to go with lorinser or barbus, but eibach does make a good set of springs for clk and they are alot cheaper. Check with dazzmotorsport or wheelpower to see if they make a adapter for your c-5's but I would recomend a wheel made for mercedes because adapters are never that good. There are some nice deals on wheels in the classifieds of mbworld. Good luck!
P.S. I have 19x8.5 and 9.5 rears lowenhart LD1's on mine with lorinser springs and the rear fit is tight but it works.
Old Feb 26, 2002 | 01:02 PM
CLKqueen's Avatar
Question what tire size should i go with?
especially for the rear. i have 275/35/19 yokos and they look real real wide
Old Feb 26, 2002 | 01:10 PM
Harris's Avatar
I had 265/35/18 with 10x18 wheels on my CLK430 before and they just barely make it. I really doubt if 275/35/19 is the right size for yr car. I think it should be 265/30/19 instead.
Good luck!
Old Feb 26, 2002 | 02:09 PM
IDOITBST's Avatar
CLKqueen its not taboo to stick jap rims on the benz :)
i have SSR MINERVA (jap wheels) 19x8.5 19x9.5 w/ 245/35 & 265/30 tires...!!!!! 3 piece wheels and lighter almost all other 19z that fit a benz..!!!
CLIFF
Old Feb 26, 2002 | 04:29 PM
lee2375's Avatar
W212 E63, Audi R8 4.2, Panamera S, Range Rover Sport GT
There isn't enough difference in the backspacing to run an adapter. You prob be better off getting wheels drilled 5:112 already.
235/35/19 and 265/30/19 is the correct fitment on that car. As long as the offset is higher than 31 you should not need any mods to the fenders.
