Bumper repair cost??
Old Sep 27, 2012 | 08:54 AM
ThatsMyDawg's Avatar
SL 400
Hello all. My factory front bumper is pretty messed up down where the grill insert would go. All kinds of cracks and scrapes, etc from prior owner.All of those vertical tabs are broken as well. (They probably hit a curb stop).
Anyway, I was planning on replacing the front bumper anyway but found a new OEM bumper that has a 2 or 3" crack on the corner. Other than that it is a perfect new bumper. (Unpainted).
I don't know body work cost at all and was trying to get a ball park on having the fiberglass crack repaired. The bumper is $200 as is but if the cost to fix is to much then I can just get a undamaged new one. $200 is pretty good for what I have seen online for new bumpers but others may know more.
Thanks for any help.
Old Sep 28, 2012 | 10:37 PM
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
I own a shop from the description anywhere from 75-150 plus paint
Old Sep 29, 2012 | 12:28 PM
SL 400
Decided to pull the trigger and buy it. Was able to talk him down a little more because of the crack, so pretty happy. After the part you mailed me arrives I'll get the work done.
Thanks for the reply.
Old Sep 29, 2012 | 07:56 PM
Should have it Tuesday
Old Sep 30, 2012 | 07:39 PM
SL 400
Ok, good.
Picked up the bumper and the crack is not as bad as I thought but still every bit of 3 inches. At least it's in the garage now.
Old Sep 30, 2012 | 07:44 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Weellll....
no disrespect intended, but anyone who thinks they can work on one of these bumpers for 75-150 has not spent any time on one. They are the biggest pain to fill, prep, and paint of just about anything I have tried. They are very, very difficult to work with and get right. If you can find one that's together, that's your best bet, and it still won't look perfect. If you love your car and are going to keep it forever, then you'll want to buy a new one. Very expensive.
Sorry, just my experience.
Old Sep 30, 2012 | 07:49 PM
SL 400
Will post pics of the finished results. I am an optimistic kinda guy, all will be we'll no matter what the final cost.
Old Oct 2, 2012 | 08:23 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Doe to a minor accident to the left front corner (cosmetic) car is in the shop now having the front bumper replaced.
Following are the back of the envelope numbers the insurance company adjuster and shop agreed on, for the repair.
Parts and materials
$ 505 Bumper cover (new oem reconditioned not available).
$ 288 Valance panel (new oem reconditioned not available).
$ 192 Filler, Front Bumper
$ 67 Misc brackets, clips
$ 294 Paint materials including flex additive, adhesion promoter
Labor
$ 968 Disassemble, assembly, alignment, preparation, refinish etc.
Note: Labor rate used above is $38/hr except painting at $18/hr
Old Oct 2, 2012 | 10:22 PM
allenjdmb's Avatar
yep.....
that's more reality, and keep in mind the 320 cover is cheaper than the 430.
Old Oct 2, 2012 | 11:21 PM
Serndipity's Avatar
2001 CLK320 Cabrio
FWIW, the 320 Cabrio trim (e.g. bumper, rocker panels etc.) is not the same as the 320 Coupe (e.g. more sporty).
Old Oct 3, 2012 | 02:56 PM
mint's Avatar
2013 FIAT Abarth 500
Are you comparing non-AMG vs AMG kit? Because I'm pretty sure that the exterior parts on a non-AMG & AMG kits will fit on both coupes and cabs.
Now if you're talking about non-AMG vs AMG, that's different and not based on coupe/cab as both can be fitted with either option.
Old Oct 3, 2012 | 04:16 PM
Serndipity's Avatar
2001 CLK320 Cabrio
No, I was only referring to how they were equipped from the factory (e.g. OEM).
Old Oct 3, 2012 | 06:26 PM
SL 400
I'm still waiting on one part then I will get the work done on the bumper. It will be in a different ball park than what an insurance claim would detail.
I'm replacing the cover only.
Will post a pic after the work has been done.
Thanks.
Old Oct 3, 2012 | 07:08 PM
RickTheRuler727's Avatar
'99 CLK320, '91 BMW 325Ic
Jeez $2400 for a new bumper cover...lol!! I need to be in the auto body biz...
For what it's worth, I had the screw holes for the front plate filled on mine, and re-sprayed for $250.. Looks perfect....
