Front side seat squeaks
dealer wanted $125 to put some saddle soap on the leather by the plastic base. I thought I should try by my self first... but haven't had the time to get to it...
Hi - My driver site seat makes lots of noises (squeaks). Is there a remedy other than using WD40 (it smells)? - Thanks
-s-
Anyway what I have accumulated about this subject is that in MY99 CLK, the chairs squeak because the leather seats rub against the plastic frame causing the noise; on both the passenger side and driver sides seat. The remedy by MBUSA was to change out the lower portions of the seat to a different material in all MY 00 + years.
The most common fixes for MY99 are to lubricate the parts with some sort of lubrication grease. This is only a temporary fix because the lubricant will dry out. You can also apply a layer of felt or cloth in between the spots that rub but this is also a temporary fix because the felt usually ends up moving out of place and you have to re-adjust it every couple of sittings. My only problem is that I can never see or hear exactly whats rubbing so I can't try either method.
Hope this answers your question.
If anyone has any pics that can point out exactly where this queaky occours, it would be greatly appreciated.
Install it on the Plastic Covers and The Squeak WILL Go away!
I Have Done Several of the Squeaky Seats..and This will Fix it!
Where can I purchase this felt?how much does it cost? and where do you apply it?
Mercedes has Some Bulk FELT with a Adhesive on one side to secure it that is Used for the dreaded squeak!
Mark if this is true you have just made me the happiest ive been in for A LONG time if that means anything. Do you know how embarassing it is to be on a first date with a shorty and you driving and talking and it keeps squeaking? You lose like 453 cool points and extend the sex game wait for AT LEAST another week........
Also, ALL model 00+ cars did not require the fix, as the ones with orthopedic seats (multicontour) don't have leather in the problem area.
-s-
