Battery recommendations (non OEM)
as an example
http://www.overstockedcomputer.com/p....asp?ID=846054
This webpage will tell you how to keep a charge while swapping a battery. As an aside, resetting the steering, windows, stereo, sunroof, and seats doesn't take very long.
Additionally, always remove the battery's negative cable first, which will isolate the battery from chassis ground.
Even when the ignition switch is fully off, some sensitive electronic circuits remain operational. Another reason is that, when removing the positive cable, it's very likely that the wrench will make contact with nearby chassis ground and become am 'arc' welding machine. For the same reason, it's best not to connect a second battery just to avoid having to reset a couple of items.
Likewise, when installing the battery, always connect the negative cable last.
The procedure to reset the ESP, windows, seats and radio code are covered in your owners manual.
The correct battery size for a W208 is H8. In addition to having the electrical capacity, it has the front and rear bottom flanges to securely hold it in place. Although Walmart sells them for $120, I bought the MB battery from the dealer for only $20 more.
Believe it of not, the battery has lasted 11 years and was the Original Battery from Mercedes. Im sure it would have lasted longer if I would have disconnected the battery before leaving my car parked in the garage for 6 months untouched. My fault.
Remember to always disconnect your car batterys if you are gonna leave your car parked for a long time. Meaning months and months.
Im looking for a battery to meet these standards.lol
