Audio question
Old Dec 29, 2012 | 05:16 AM
FF_EMT's Avatar
02 CLK430, 86 BMW 325, 66 GTmustang, 97 GTmustang
Audio question
So I have located a navi unit from a w210 OKs this head unit a plug and play our do I need other things to make it work? I have a 2002 430
Posted from Mbworld.org App for Android
Old Dec 29, 2012 | 05:17 AM
FF_EMT's Avatar
Originally Posted by FF_EMT
So I have located a navi unit from a w210 is this head unit a plug and play our do I need other things to make it work? I have a 2002 430
Old Dec 29, 2012 | 01:52 PM
MarcusF's Avatar
2002 CLK430
Which HU originally came with your car?
Old Dec 29, 2012 | 05:23 PM
FF_EMT's Avatar
The basic single stack one non navi
Old Dec 29, 2012 | 05:24 PM
FF_EMT's Avatar
I have the Bose non navi head unit
FF_EMT's Avatar
Old Dec 30, 2012 | 01:19 AM
Scott Simoncic's Avatar
2001 CLK55 AMG
Not exactly plug and play. There are retrofit harnesses out there that can get it to the plug and play point, however, you still will need to cut the center divider after you take the filler pocket. Also, if you want the directions to show up on the multifunction screen below your speedo, you will need the dealer to tell program the car to let it know it has the COMAND unit installed. You also *should* install the support bracket, but that's optional.
