AC ISSUE
Old Mar 14, 2013 | 08:09 PM
jkiddd33's Avatar
2005 E55 AMG
AC ISSUE
So the EC light was on = Freon low most likely.
Had it recharged and filled with DYE so we could find the leak.
Found a TINY leak. Compressor works fine thank God.
Light was off for about a day.
The light came back on, but I am able to BYPASS it by Restarting the car and clicking the EC button off. AC works fine!
From previous posts when you hold RESET and go to #7, that tells you the Freon level.
Anything below 10 is "low". Mine fluctuates from 14-6, to 3 at times.
Here are my 2 questions:
1. What # should the Freon be at?
2. Do I need to CLEAR the error codes with a scanner to keep that EC light off? I recently unplugged the battery for other reasons and had to reprogram quite a few things. I was told this way would ALSO clear the error codes.
Thanks ahead of time!
Old Mar 15, 2013 | 01:36 AM
MarcusF's Avatar
2002 CLK430
When my car is started, and the AC is turned on, without touching the gas, as high as 15. 7 while driving, 11/12 while waiting at lights. Mine has never leaked and blows very cold air. Thats a photo of an infrared pyrometer checking the vent temperature.
