2000 clk 430 NOT running normal
I changed air filters and fuel filter.
When i press the gas it cuts out and has no power?
I cleaned the mass air flow sensor but didnt effect anything?
Does anyone have any ideas what could be wrong?
Plug the reader in to the ODBII port. The port is under the dash, to the right beneath the steering wheel area, and there is a clip covering it. After it's plugged in, record the numbers that appear. Many code readers will allow you to clear the codes, which I would do after writing them down. At any rate, take the codes you wrote down and look them up at this webpage. If the codes seem confusing, just post back in this thread and people will be happy to tell you what they mean.
I would start with this, put the old filter back on and see, is the pipe bent?
