2003 CLK 320 (W208) Gauge Cluster....
I have some issues with the current gauge cluster (Temp, clock not reading) and I had asked a repair shop if they could help....actually asked 2. One said yes, the other said it is non-repairable.
Is that true???
I wanted white dials, but cannot find any...and the one shop that said I would need to buy a new cluster, said none were available...which I find hard to believe.
Any thoughts or recommendations would be appreciated. Thanks!!!
Don't waste your time having a mechanic doing it as the cost will be high and the results will be less than desirable. There are a few electronics houses that will repair/replace the ribbon and thermoblocks that hold the ribbon in place for about 115 USD. Try BBA Reman - their website is: http://www.bba-reman.com/us/
The problem with the cluster is that the ribbon cable is glued and over time it separates from the LCD. On mine it was really strange. If the car was used all week it would be fine, leave it in the garage during the weekend and the cluster segments would drop out. Drive the car on Monday for more than 30 minutes and it would come back. This went on for a few weeks. Left the car for more than a week and it wouldn't come back no matter how long the car was driven. Originally though the battery was weak. Sent the cluster out and it now is repaired. No issues.
They warranty their work for life on the cluster. All you have to do is remove the cluster which is fairly easy and pack it up in a double box - bubble wrap the cluster VERY THICK and ship it out. They'll fix it in a couple of days. Expect not to drive the car for at least 5 days.
Is it worth it - definately.
It includes some pics as well as written guidance.
Good luck
