Lambo doors
I put Lamborghini doors on my clk 320 when the removed the door and put the kit and put it back together now my car door won't lock my remote doesn't work I called the dealer ship the said that I might need a new set of keys. Can anyone help!
1- You have an aftermarket alarm. It depends on what it is and how it's wired if it has anything to do with your problem.
2- You can't have 2 alarms working simultaneously. Which one is your car using?
3- What "lambo" door kit do you have? Most I've seen are hack jobs and have problems with the hinges. Is the door even latching correctly to engage keyless entry/alarm?
4- Your "friend" seems to have the problem and should be able to do a clean complete install if he's a professional. Did he install the alarm too?
5- Why are we talking about vacuum leaks on a door? The door might not close properly due to a universal fit vertical Chinese door hinge on a strut that probably does not support its weight. A- The door latch was not designed to work with this and therefore probably is not engaging properly. B- The alarm has a flaw in the wiring or module.
